Need opinion on compression test results!
Old Apr 8, 2014 | 02:46 PM
TreatsIX's Avatar
One week ago my IX started blowing the upper pipe off the throttle body on hard pulls.
I used hairspray and it stuck tight, however the car would now have a weird bucking sensation on full boost, almost like a 'bark'.
Fast-forward to today and now the car is blowing alot of oil smoke from the exhaust.
Did a compression test that returned, 130,130,130, 45.
Just looking for some insight, rings? head gasket?
Thanks,
- Philip
Old Apr 8, 2014 | 03:30 PM
jrainwater's Avatar
Uh yeah that 45 could be any one of the things you just mentioned. As far as ideas only a leak down will show what the culprit really is. Good luck man.
Old Apr 8, 2014 | 03:32 PM
jrainwater's Avatar
I had a buddy and his Evo had similar results to yours and it turned out to be a bad valve spring. That was an easy fix. It's not always the rings or a blow head gasket. Hope for the best.
Old Apr 22, 2014 | 09:08 PM
Vrbigdish's Avatar
Is the smoke all blue(oil)? Hows the coolant level/color?
Old Apr 22, 2014 | 10:52 PM
EVOjunky's Avatar
I had the same issue and it was actually a cracked piston from a crappy tune. Regardless what the issue is I see you needing to have the head pulled unless its only the valve spring, which I don't know how they go bad unless it would break and let the valve hang which results in the same scenario so I would just do that for a proper inspection.
Old Apr 23, 2014 | 05:48 AM
boost556's Avatar
best advice here would be to pull the head and inspect cuz you know there is definitely a problem, if its not in the head then move on to the block could also be a crack ringland or piston 45 says it all motor is hurt hope all works out well .
Old Apr 23, 2014 | 06:44 AM
Vrbigdish's Avatar
+1 what boost said.
lostsoulsevo
28
Feb 9, 2017 05:52 PM
sturz0
Jan 1, 2015 12:32 PM
SeahawksOilers
12
Apr 26, 2014 09:11 AM
Jrah2987
Dec 17, 2010 09:19 AM
02-Lancer-Es
Lancer Engine Tech
12
Jan 17, 2009 01:35 AM
