Melted No. 1 Piston Intake Side....Twice
Old Apr 21, 2014 | 12:05 PM
Faisalm's Avatar
Originally Posted by slowsrt4:(
looks like clogged injector possibly. before you start the car on the rebuilt motor, have your injectors flow tested and cleaned
Originally Posted by pcfreakguy
Check your injectors, maybe clogged. I had a similar issues issue when i had my 9, one of the injectors was very dirty. Cylinder number 3 was getting little fuel and the piston eat into the cylinder wall, and ruined my stock short block.
You guys did read his post, yes? He clearly stated that he sent his injectors over to FIC to have them tested and they were flowing properly.
Old Apr 21, 2014 | 12:09 PM
Faisalm's Avatar
Originally Posted by Carbonlution
eh WRONG!.
ams, skunk and AEM for example give you 10-15HP at the top, but they **** up rest of the register on the way up!
car ive seen with powerfull low to midrange and continues all the way up had OEM intakes.. And everyone was portes..
i my self have a ported intake and oem trotthlebody.. engine is responding from 3.000rpm and doesnt stop until i hit the rpm limiter at 7800..
while when i had the Magnus Race intake, it was worse! way off!
Sorry to burst your bubble, but Buschur already did back to back tests on several intake manifolds and he states in his test that there is no other IM that will make more power up to 5,000 RPM than a ported OEM IM..
http://highboostforum.com/forum/show...and-facts-only
Back on to the OPs subject.
todd6027's Avatar
check injector resistor pack / fuel pressure reg / remove pipe from fuel pressure solenoid and pipe direct to manifold /fuel pump relays or hardwire pump and get an fpr with a guage
Old Apr 21, 2014 | 12:36 PM
ilikeppie's Avatar
Thanks for the replies guys. The injectors were sent in and are flowing properly, I have removed the resistor pack as these are the high impedence FIC 2150cc injectors.
I do have a FPR with gauge however I do not have a log with it. During a couple of dyno pules before it blew I watched the FPR gauge and it held strong 80-85 psi through boost.
Old Apr 21, 2014 | 01:27 PM
wreckleford's Avatar
Look if your map has a pulsewidth trim on that cylinder. Maybe it was put in there accidentally.
Old Apr 21, 2014 | 02:18 PM
ilikeppie's Avatar
We actually looked at the individual cylinder trims before it blew, none were changed.
Old Apr 21, 2014 | 05:52 PM
galantman03's Avatar
are you sure that injector signal is getting to the injector? even the the injector is fine i would check to see that the ecu is indeed outputting the fire signal. idk if the log reads the signal at the exit point of the ecu or somewhere else
Old Apr 21, 2014 | 06:18 PM
Roadrunr's Avatar
I may be out of line, but I would try a reputable tuner. Yes I know you have had two, maybe two bad ones in a row!!!
Old Apr 21, 2014 | 06:25 PM
asu11's Avatar
Interested in seeing the logs also.
Old Apr 21, 2014 | 07:24 PM
Jsiebert's Avatar
Combo bad cam angle sensor bad injector.
Old Apr 21, 2014 | 10:49 PM
batty200's Avatar
AEM apparently doesn't have a fail safe in it for a failure of the Cam sensor like stock does. Buschur and several others have commented about it in the past. It is because of that it is recommended to use a NEW OEM Cam sensor and replace it on a regular basis plus use a Cam sensor heat shield.
Good luck.
Old Apr 22, 2014 | 01:00 AM
foxbat's Avatar
I think this was caused by lean AFR, if you have checked the injectors then the next suspect would be the fuel pump. What max boost did you run while on the dyno?
Old Apr 22, 2014 | 02:59 AM
dsm nexus's Avatar
How is your engine harness? Is the clip for the injector solid?
Old Apr 22, 2014 | 08:56 AM
mrfred's Avatar
i was thinking the same. my other suggestion would be to send in the aem ems to have it checked out or just buy a series 2 or infinity or stock ecu.
Old Apr 22, 2014 | 09:05 AM
ilikeppie's Avatar
Last night I checked the fuel filter and it looked good, I also checked voltage at the injector wiring harness clips all have 12v.
I never thought of the cam sensor being an issue. Max boost on the dyno this time was 36psi and fuel pressure was holding strong through the pull.
Attached are some logs from the pulls, let me know what you guys see. Also you will see that the knock sensor was noisy, we thought this was just engine noise given that it was picking up as much or more with a no boost acceleration pull on the dyno see "knocktest"
File Type: zip
File Type: zip
File Type: zip
File Type: zip
