evo maf pinout requested
Hey guys, I was looking for a pinout of the maf sensor. However upon google-ing several comnbinations I did not see a direct diagram of the Evo sensor. Most of the DSM-evo stuff just tells you which wire to connect to which wire on each sensor. I am not doing any thing with a DSM here, so I was hoping to find a legitimate diagram of what each pin on that plug corresponds to.
thanks!!
thanks!!
Code:
Turbo 1G/GVR4 MAF pinout Pin 1 = Reset Pin 2 = Airflow Hz Pin 3 = +12 Volt from MPI Pin 4 = +5 Volt Sensor Power Pin 5 Not Connected Pin 6 = Sensor Ground Pin 7 = Barometer Pin 8 = Intake Air Temp 2G/3G/EVO MAF pinout Pin 1 = +5 Volt Sensor Power Pin 2 = Barometer Pin 3 = Airflow Hz Pin 4 = +12 Volt from MPI Pin 5 = Sensor Ground Pin 6 = Intake Air Temp Pin 7 = Reset Pin 8 Not Connected So, the correct crossover wiring to our MAS plug is: 3G/EVO Pin 1 to 1G MAS Pin 4 3G/EVO Pin 2 to 1G MAS Pin 7 3G/EVO Pin 3 to 1G MAS Pin 2 3G/EVO Pin 4 to 1G MAS Pin 3 3G/EVO Pin 5 to 1G MAS Pin 6 3G/EVO Pin 6 to 1G MAS Pin 8 3G/EVO Pin 7 to 1G MAS Pin 1
This is the best I can come up with. I was hoping to find something more official than a notepad on a DSM website.. Something evo related cause I hath no faith in dsm stuff, its been hacked to hell and back.
Also what sensor uses 12v on the MAF? Is the HZ reading using an amplitude of 12v?
FLASH1970
Lancer Engine Management / Tuning Forums
Aug 3, 2024 03:31 PM
wang4u
May 8, 2013 09:19 AM
