what parts do I need for head gasket job
Old Apr 29, 2014 | 06:36 AM
88888's Avatar
Valves and says it all. I have here
1. Head gasket (OEM)
2. Valve cover and spark plug seals
3. Apr head studs
4. Gates timing belt
Are there everything I would need to get this job done?
Now the car did over heat a bit and I'm not sure if my head needs to be shimmed. How do I check to see if head needs to be evened out?
And also, would I have to play with Valves and shim the valves if I had my head shimmed as well?
Thank you!
Old Apr 29, 2014 | 07:01 AM
sr20det91's Avatar
I would change the exhaust and intake mani gaskets as well. Also if the car overheated you would be crazy not to have it resurfaced and risk having to do all that work over again. I learned that lesson the hard way.
Old Apr 29, 2014 | 07:36 AM
88888's Avatar
Thanks for the input. Would I have to resurface the block as well or just the head?
Would I have to reshim the valves and adjust according to the material that has been removed due to head being shaved off?
Old Apr 29, 2014 | 09:11 AM
sr20det91's Avatar
Resurfacing the head does not require any additional work to the valves. No shimming needs to be done on valves that are hydraulically adjusted like the ones we have on evos. The top of the block does not need resurfaced, unlike the aluminum head the block is iron and not prone to warpage. A good cleaning with a razor blade and brake cleaner should do. Be careful of gouging though.
Old Apr 29, 2014 | 09:14 AM
llDemonll's Avatar
100% resurface the head if it overheated at all. take it to a machine shop and they will measure it for you and tell you if it needs to be resurfaced
last thing you want to do is the same job all over again
Old Apr 29, 2014 | 09:16 AM
sr20det91's Avatar
One more thought on resurfacing the head. If its the 1st time it has ever been resurfaced you have nothing to worry about. But, only have the machine shop remove enough material to level it out and clean it up. On heads that have had too much material removed there is risk of oil starvation due to a teardrop shaped oil passage that becomes to small if too much surface is removed.that can be gixed with a bit of porting to the passage. You should not be concerned with that if your just getting it cleaned up on a virgin head.
Old Apr 29, 2014 | 09:26 AM
slowsrt4:('s Avatar
if you're going to have the head off you might as well do a valve job so that you don't have to do it down the road
Old Apr 29, 2014 | 09:43 AM
88888's Avatar
awesome info.
Lastly, do i need to remove cams and valves, etc if i am going to get it resurfaced?
Old Apr 29, 2014 | 12:24 PM
xXANCHORMONXx's Avatar
Cam seals, valve stem seals, valve cover gasket, spark plug gasket, intake manifold gasket, exhuast manifold gasket, thermostat housing gasket, cam position sensor housing gasket, headgasket
Have the head taken apart and checked in and out
Evo_Goodness
Dec 19, 2020 02:39 PM
Black_EVO_MR
Nov 9, 2016 05:10 PM
tripletaco
Lancer Engine Tech
Nov 2, 2015 06:53 AM
88888
11
Jun 5, 2014 07:58 PM
AWDTerror
Oct 23, 2012 05:27 AM
