FP ballbearing
Old Aug 22, 2014 | 09:35 PM
  #91
Yogi_B's Avatar
There is this thread over on the MLR:
http://www.lancerregister.com/showthread.php?t=489425
For this:
http://store.forcedperformance.net/m...e=Lancer-Turbo
And this:
Old Aug 22, 2014 | 10:34 PM
  #92
Nagua's Avatar
Originally Posted by batty200
FP just blew the game wide open with a billet CHRA. I want an HTA Green in the worst way! Hahaha. I just want to try one out before I buy it to see if it's better than my 6262 overall.
Good luck with that. Just installed a CBRD full Ball bearing Turbo and this son a ***** rocks.
Old Aug 23, 2014 | 04:58 AM
  #93
mx4life85's Avatar
How do each of those turbos compare to a Green/Red/Black ?
Old Aug 23, 2014 | 07:41 AM
  #94
TommiM's Avatar
Damn that is really cool on those new CHRA setups. I will say this, FP is always getting crap slung at them but they still keep interested in our platform and deliver newer and better stuff for us regardless. Hopefully these new setups will solve this oil issue.
Old Aug 23, 2014 | 09:33 AM
  #95
EVONOT's Avatar
Ive been running my dbb red with the stock lines for a minute. And its perfect no smoke or crazy shaft play at 25-27 psi. But thats just my expierence.
Old Aug 23, 2014 | 09:00 PM
  #96
michaelrc51's Avatar
Originally Posted by Fireescape
It's a strange attitude that people have towards certain products. It seems that people are quite happy to just run the line that a manufacturer puts out, blindly regurgitating it at every given opportunity.
This is the story that FP run, but ask them to recommend an actual setup and they go all quite. Wonder why that is - actually no need to wonder because FP themselves actually tell you
And this is a problem in my mind. So I spend $300 dollars, or more, and many hours building a crankcase pressure relieve system. Two -10's out of the valve cover to a sealed catch can and a -12 to my intake tube for suction.
Does this work? No it doesn't, but what can I do. I can't go to FP and say "I built what you said and my turbo is still leaking oil like crazy". I can't say this because FP won't say what I should build. So what can people do? It's pointless complaining to FP, "it's crankcase pressure that causing the leaks" they say, "how do I releive this to stop the leak?" I ask, "not telling" FP reply. So I build what is generally regarded as a bomb proof crankcase pressure releive system, which does absolutely nothing, but there's no comeback to FP because THEY didn't tell you what to build.
So crankcase pressure is the problem michaelrc51, no it is not! At least not all the time! How do I know, see post #59 of this thread. Crankcase pressure can't be the issue because my turbo leaked oil on a dynamic balancer, and on this machine there is no crankcase pressure because there is no crankcase!
So I convert my turbo to a journal bearing. Does it now leak, I hear you ask. No, it does not. Same setup, same crankcase pressure, same engine, same power output. But no leak. What does this tell me? It tells me that there is a fundamental problem with the FP BB turbo that causes it to leak masses of oil when a journal bearing turbo doesn't.
But your turbo must be faulty I hear you say. Is that right! I have my turbo checked by a turbo mechanic, does he find a problem, is there something wrong with my turbo. No, he can't find anything, the turbo looks fine.
There is a suggestion that this is a rare problem. I myself know of at least 12 FP BB turbos that are leaking oil, just in Australia. Is every turbo leaking? No, but many are, too many to dismiss it as a anomaly. We have just has a recall by Mitsubishi here in Australia for a problem with a circuit board in the headlight system that can crack, causing the car's headlights to turbo off. Has every Mitsubishi recalled had this problem? No, just a small quantity, but still Mitsubishi recall 115,000 cars to replace the circuit boards, just in case.
Forced Performance talk about overspeeding the turbo as a possible cause of damage that could cause the leaking oil problem. In post #64 I ask them for some information about this overspeeding. I ask because it's hard to avoid it if you don't know what conditions cause it. I ask about RPM, boost and flow conditions that cause this overspeed situation. Do I get a reply from FP about this, not as yet. I ask about having a local (Australian) turbo mechanic of FP choice, check my turbo for issues, just to cut down on costs to me (which at this point, to have a non leaking turbo have past $1500 on top of the $2500 turbo purchase price). Does Forced Performance contact me via PM to help with this? NO, they do not. I feel that they won't do this because it would cost them a fortune if everyone with a leaking turbo start putting claims in for repairs or replacements.
At this point I'd be happy with something from FP like "you take the leaking cartridge to our Australian distributor and we'll get it checked, if there is something wrong with the manufacturing we'll replace it, at our expense and if there is found that there is no problem with the cartridge, and it still leaks oil on a dynamic balancer, with no crankcase pressure, we'll give your purchase price back". Can't see this happening, but it's nice to dream.
I stated that due to multiple people actually proving that the issue was a crankcase ventilation issue. Some even logged different setups and proved that the design that was recommended actually worked and solved the problem.
I do believe that the majority of the problems are still crank case ventilation issues.
I think the hardest thing is to pin point an issue like this. Everyone's setup are so much different, even cars with very similar parts can still be so much different in terms of their crank case pressure and ventilation setup.
I don't know what the issue is with your's but I would like to know. The only thing I could think of is that the gas seals were "blown" before it went on the dynamic balancer. I think the only real way to find out is to send it to FP and see what they find.
I moved on to a different turbo.
Old Jan 4, 2015 | 01:11 PM
  #97
Benja's Avatar
I had the same leaking BB Black issue with oil dripping out the comp outlet and pooling heavily into the inlet. Filled the cooler with oil etc etc.
Removed the filter housing feed line.
Made up a new 4AN braided feed line from the original head location with a 0.9mm restrictor same as you would add to a Garrett GT/GTX setup.
Seems to have fixed the issue immediately for now, leaking oil stopped instantly.
hutch959
14
Apr 6, 2016 12:42 AM
michaelanjolo
Feb 10, 2016 12:02 AM
Anubis18
20
Oct 12, 2015 06:53 AM
kaj
Aug 13, 2015 01:37 PM
