Whinning noise Tranny or Tcase? HELP
Old Jun 9, 2014 | 03:22 PM
JOLLY300's Avatar
Question Whinning noise Tranny or Tcase? HELP
has anyone come across this noise before? i thought it was the TOB so i changed it but this noise is still there. can you please click on the link below and watch the whole video to get a better understanding on how the noise changes.
https://www.youtube.com/watch?v=aYJk...ature=youtu.be
Old Jul 12, 2014 | 10:34 PM
AlphaKennyBody's Avatar
Bump!
Old Jul 12, 2014 | 10:43 PM
RussellDaniel's Avatar
Thats not your transfercase so you can rule that out.
Old Jul 13, 2014 | 07:09 AM
MitsuJDM's Avatar
Not the T-case. It's 100% internal in the transmission. I'd say input shaft bearing seeing as how the noise goes away at idle with the clutch disengaged. But usually, an input shaft bearing sounds more like a rattle or knocking sound. This may be a gear that has a few chipped of missing teeth. Sounds like you need the transmission rebuild.
Old Jul 13, 2014 | 07:12 AM
03nevaevolution's Avatar
Veteran: Army
Almost sounds like the cluth or your flywheel. Did you have your flywheel done or replaced when you put in the twin? if not, could be your problem. I would suggest contacting a Evo transmission shop like Shep or Jacks for advise.
Old Jul 13, 2014 | 07:14 AM
oscarquinones's Avatar
that is the transmission man. You better get reuild before it start o do more damages
silverevo05
20
Oct 10, 2020 08:58 AM
babaz7
Oct 2, 2017 05:22 PM
RalliAaron
Feb 10, 2012 01:16 PM
hataeeun
May 4, 2010 05:32 PM
Scratchy
Jun 9, 2009 01:44 PM
