EVO IV's AYC problem
Old Aug 8, 2002 | 05:20 AM
Lan Evo's Avatar
Based on what I read on MLR, the EVO IV and early V's AYC are prone to problems (ECU, and clutch discs). What can be done to fix this other that swapping out the complete unit for an RS mechanical unit? However, this way, I have to get new drive shafts and axles, right?
Will getting a Cusco LSD to replace the LSD component in AYC be able to fit that? Or, once and for all, just replace the complete AYC (ECU, wiring, AYC itself) with VI or TME AYC units?
Thanks in advance
Old Aug 8, 2002 | 08:28 PM
Lan Evo's Avatar
When you say replacing the stock LSD with a Cusco unit (I have heard terrible stories about KAAZ ). Can I leave the AYC disconnected and still have it function as a mechanical LSD??
Since replacing only the LSD portion of the AYC seems to be most cost efficient to me
Thanks, C
Old Aug 10, 2002 | 10:56 AM
Lan Evo's Avatar
Hey, Clau, or anyone?
Old Sep 4, 2002 | 02:40 PM
JoCCe's Avatar
I have a Cusco LSD for sale ... It´s been fitted on my car only for about 4000 km ... It´s made to replace the standard visco ... Anyone???
/JoCCe
Old Oct 7, 2002 | 06:25 AM
Braf's Avatar
If you disable your AYC system you are now running an expensive and heavy open diff.
Old Oct 8, 2002 | 03:52 AM
jigga's Avatar
(quoted) Vehicles produced between December 20th 1996 and July 17th 1998 were affected by what youre describing. CN9a (EvoIV): 69 Units, CP9A (Evo V): 141 Units.
The corrective part numbers for these vehicles are:- MR368576 (Evo IV) and MR405906 (Evo V). The part number should be clearly visable on a label attached to the ECU, which is situated behind the centre console. Identification of the corrected ECU should show a black circle 5mm diameter half way up the adhesive label on the right hand side of the AYC ECU (this is the same label that displays the part no.)
The ECU replacement was due to the clutches in the torque transfer differential remaining disengaged when the engine was started. This could result in damaging the rear axle differential gear.
Hope this helps to clarify the situation. (Quoted)
regards,
LEE
Nawshad
Sep 28, 2016 01:46 PM
Blitzboyii
May 3, 2016 11:53 PM
RoryE4
Sep 21, 2015 05:40 PM
Ferp
Sep 15, 2015 08:52 AM
GsrEviluTionX
Dec 24, 2011 07:30 PM
