Buschur Racing's electric power steering for the EVO8-9
Old Jun 17, 2014 | 12:21 PM
evolve_VIII's Avatar
Is roughly $1400 worth the extra 15ish HP gain? I do like the idea and the innovation. (among being the first to develop tons of stuff for our platform). Just wondering if the time spent doing the R&D would be worth the gains.
I have played with the idea of going to a manual rack to remove the P/S completely but sucks to drive with wide tires. Drag cars typically dont see the street so no power steering doesnt really matter.
Old Jun 17, 2014 | 01:16 PM
David Buschur's Avatar
Originally Posted by 94AWDcoupe
another way to explain it would be yes there is more load on the alternator. but the extra work needed to make that extra 6 amps (or whatevr it draws) is no where near as much load as driving a mechanical belt and pump. so there would be nice gains. and its 4 lbs lighter overall. very nice indeed.
dave, does this pump sense load? I only see a power and ground wire.
Yes, it somehow senses load, when you turn the wheel it instantly picks up RPM, you can hear it when the car is off.
Old Jun 17, 2014 | 02:29 PM
420a-t's Avatar
Depends if you're at that point with your car that you'd like to have this mod. Same goes with lots of other mods...tubular subframe, small brakes for drag racing, etc etc. This mod will clean up the bay and also lessen the load on the motor, so it will really help with no mods, as well as the cars that are "all-out" cars
Old Jun 17, 2014 | 04:33 PM
Faisalm's Avatar
Yeah I guess that + the electric water pump would make sense when your at a point where you can't make any more power without changing out a turbo or something of that nature.. ~50whp from an electric pump + power steering isn't so bad at all.
Old Jun 17, 2014 | 06:44 PM
Migsubishi's Avatar
Very good product, definitely catches my interest, I just need to talk my wallet into it.
Old Jun 18, 2014 | 05:32 AM
way2qik's Avatar
Originally Posted by JDavenport
That's good information. Sorry, but as an engineer the statement of 'more load on the alternator will not make it any harder to turn' caused a knee jerk reaction. Physics is physics. But it sounds like the trade off is pretty good.
LOL... On the technicality you may be right, like many engineers often are... But what I know for sure is that this is a proven trick that hot-rodders have been doing for years and years.
Back in the early 90s when I was trying to make a 5.0 Mustang go as fast as it could go on my limited budget, by-passing the power-steering pump with a "short belt" at the track was a for-sure way to pick up at least a .10th in the 1/4 mile.
Putting an electric waterpump on your car does the exact same thing in most cases.
Old Jun 18, 2014 | 07:24 AM
nollij's Avatar
Eh. That was my sentiment too but then I decided on "it depends how both pumps operate."
The mechanical pump is always driven with likely a proportional control on a recirculation valve so the pump is always making the pressure header + recirculation flow.
On the electric, it might be using a proportional control on the voltage input to the pump motor without a recirculation flow so the only "draw" is maintaining the pressure header and when the steering rack gets pushed either way and it needs to turn on to make back up that pressure.
Granted, I am not intimately familiar with the electronics of this system or even power steering systems in general. But, I can believe that it is possible to make a DC motor driven system more efficient than a mechanical pump that is always driven at varying rpms without a whole lot of effort.
Old Jun 18, 2014 | 09:23 AM
211Ratsbud's Avatar
Do cars that have these oem have pump speed control?
Old Jun 18, 2014 | 10:55 AM
nollij's Avatar
Here is a helpful post
short answer: no. These are standalone units. Other electric power steering units out there need inputs for steering angle, speed, etc. I imagine to control the pressure in the steering rack via PWM.
Old Jun 18, 2014 | 12:29 PM
94AWDcoupe's Avatar
some good general info on electric steering. I personally like the column mounted pumps that eliminate all hydro. I considered a saturn setup for my car, but they require complex controls to function.
http://www.cnet.com/news/power-steer...s-to-electric/
the other problem is I was way off on how many amps these guys draw. seems an upgraded alternator will be necessary as well.
This pump automatically senses the steering load and idles at about 150 psi, increasing to up to about 1500 psi when the demand is there. This results in about a 5 amp draw at idle, and about 50amps during hard use. This is all from the 12 volt accessory battery. These figures equate to less than one horsepower in the high power mode.
Old Jun 18, 2014 | 01:27 PM
nollij's Avatar
It depends when the current is being drawn. From a motorsport perspective, the long periods of current draw from the ignition is predominantly occurring during the long straights when the power steering would not be drawing large amounts of load. It would not be difficult to monitor voltage to determine whether a battery with a larger capacity or an upgraded alternator would be needed.
Old Jun 18, 2014 | 04:18 PM
mitsubeastlee's Avatar
Originally Posted by David Buschur
Actually......while your theory, is correct, when it comes to accessories on the engine and the trade off of the electric load vs. belt driven components the trade off isn't even close. Why do you think the OEM builders are taking all that crap off the engines in the first place.
The electric water pump kit we use to sell gains 37 whp by eliminating the water pump. The electric power steering is about 15 whp on average.
52hp is a ton not to mention the nice aesthetics of these kits.
How much does the water pump cost?
Old Jun 18, 2014 | 04:59 PM
Migsubishi's Avatar
Why did production of the electric water pump kit stop?
Old Jun 18, 2014 | 07:19 PM
projectxmatt's Avatar
Looks great Dave. If that's the pump that I think it is (which I'm pretty sure it is) hot damn thats an awesome price for this kit. I looked at attempting to build a kit using this pump on my DSM and I couldn't source the pump for cheap enough to DIY the kit for that cheap.
Old Jun 18, 2014 | 07:31 PM
EJEvo's Avatar
What's the process by which a Porsche steering pump becomes an available, stand-alone, reliable used pump?
("You keep crashing 'em, and we'll keep building these kits." ?) Just seems like an odd thing to come by.
