Port matching gasket?
Old Jun 22, 2014 | 09:58 PM
asu11's Avatar
So I have a ported ef3 with an invidia o2 housing getting ready to go on. I noticed that the oem o2 housing gasket does not exactly match the o2 housing. Should I grind down some of the gasket to match? Can you even grind the gasket since its all metal and it has a lip on it?
Old Jun 22, 2014 | 10:08 PM
Faisalm's Avatar
The thing is, that gasket matches perfectly with the turbine outlet, so I don't know how that would affect the seal between the housing and the outlet....
Invidia haven't always been the best... I haven't heard so many nice things about them...
Old Jun 24, 2014 | 07:25 AM
mrfred's Avatar
is the gasket smaller than the turbine outlet on the turbo? post a pic?
Old Jun 24, 2014 | 11:42 PM
asu11's Avatar
No but it is smaller than the o2 housing.
Old Jun 25, 2014 | 07:55 AM
mrfred's Avatar
since it doesn't block flow, no need to touch it.
Old Apr 9, 2015 | 03:52 PM
SyZyGy1394's Avatar
How about this? I already hit it slightly with the grinder and realized I should have asked on here first.
Edit: I also marked it with a sharpie. Also, I only cleaned up the outlet of the turbine housing. I didn't even make the opening any bigger.
Evo47
Jun 23, 2016 10:39 AM
2010EVOGSR
Oct 7, 2015 05:48 AM
icole
Jun 21, 2015 05:32 AM
JDavenport
13
Oct 21, 2010 09:22 PM
xxNosTankxx
Aug 19, 2009 10:00 AM
