After Cams and E85, I gained 7WHP? Help me.
Useless post of the day goes to this guy
OP- Your 255 is fine in case you were even considering the above comment.
Something is definitely not right here. How does the car feel?
Do you have any buddies with a tactrix cable and evoscan? If so I'd pull some logs yourself and go from there.
As a tuner he should be able to diagnose an issue when it's present...
Extracting 7whp and stating it's an O2 housing that's restricting 43 - 63 more ponies from being produced is just absolute BS....
Yeah he can get as offended as wants, it's your right to ask for what is yours...
And as of right now he is ignoring my phone calls and not emailing me the logs
Keep at him. I would invest in the tatrics cable at this point. You can pull the the tune and get some logs. I had similar mods to you with less aggressive cams and did almost 380 hp on pump. Not sure how far you are from Philly but would be glad to log for you.
How does the butt dyno feel?
When a tuner tells me my O2 housing is restricting 50whp from my setup, I know there's something wrong. He didn't even suggest to do a leak down test / compression test or any other test, he went straight to the poor O2 housing.. Absolute BS...
On my stock lightly ported o2 matched with the fp black on a 2.4, I made 645 on e85. I highly doubt that is the problem. Im also running a stock ported cast manifold. Im sure an aftermarket one helps but you can take a lot of material out of the stock cast one and smooth it out for great flow. I did this for a free mod instead of paying $200+ for an aftermarket.
