Timing belt issue
Old Jun 26, 2014 | 07:49 AM
jrod740's Avatar
Timing belt issue
I have been experiencing an issue with my timing belt tightening up after a few minutes of it running. I tried replacing the tensioner pulley and that did not help. I have a BLE solid tensioner but I have had it for over a year and never had this problem. I am lost for ideas on what to try or change out next.
Any ideas/suggestions? please let me know if you have any at all, I am completely lost as to what it could be. Thank you!
Old Jun 26, 2014 | 08:16 AM
Ev0ikon's Avatar
What's a BLE Solid tensioner? Got picture?
*edit*
Wait, did you replace stock hydraulic unit with a solid timing belt tensioner?
Old Jun 27, 2014 | 04:57 AM
jrod740's Avatar
*edit*
Yes I replaced the hydraulic with a solid but never had any problems. I might try going back to the hydraulic tensioner and see if that helps.
Old Jun 27, 2014 | 06:06 AM
meric's Avatar
Just would like to know the purpose of the change over. Is the car being raced or something as with a solid tensioner I would expect extra tension on the belt as it will never adjust to make up for belt stretching.
Old Jun 27, 2014 | 06:55 AM
Ev0ikon's Avatar
Originally Posted by jrod740
Yes I replaced the hydraulic with a solid but never had any problems. .
ALL/ANY belt stretch!
Solid tensioner is fine if you plan to run your engine only at a certain operating temp for a certain amount of time. You adjust the tensioner then and only then.
It’s a giant pain the behind for a street car.
Old Jun 27, 2014 | 12:46 PM
meric's Avatar
If thats the case why change to a solid if its that much of a pain
Old Jun 27, 2014 | 01:09 PM
Ev0ikon's Avatar
Good question. I could only see it on a dedicated track car.
Old Jun 27, 2014 | 02:45 PM
slowsrt4:('s Avatar
if I were you I would switch back to the hydraulic tensioner unless it is a strick 1/4 mile car, shut car down, run 1/4 mile, shut car down etc.
meckert
Jun 13, 2015 08:15 AM
Evofletch
Dec 16, 2010 02:29 PM
Evofletch
Nov 8, 2010 05:05 AM
94AWDcoupe
54
Nov 24, 2009 03:13 PM
