most valuable engine rebuild part you can buy
Old Jun 30, 2015 | 06:17 PM
  #61
Erik@MIL.SPEC's Avatar
Originally Posted by kaj
But, if the "bypass" clogs, then you have no bypass. Unless 45 micron lets a lot through?
Well, the filter Jerry is using already doesn't have a bypass and it's 45 microns
Old Jun 30, 2015 | 06:39 PM
  #62
Ted B's Avatar
You're overthinking this. A little bit of oil that makes a second pass before getting to the filter isn't worth agonizing over it. If your engine shed enough particulate in a few seconds to make an issue out of this, it would have grenaded long ago, and no filter would have saved it.
On the other hand, breaking in a fresh motor predictably generates more and larger particulate in a shorter amount of time than at any other point during the lifetime of the engine. If there is a time where eliminating the bypass is most useful, that's it.
Old Jun 30, 2015 | 08:03 PM
  #63
kaj's Avatar
kaj
Meh. Just theorizing/bench racing.
My cars have done fine over the years. I'm not too worried.
Old Aug 2, 2015 | 10:07 AM
  #64
Originally Posted by 94AWDcoupe
another nice thing about this filter is you dont have to change the oil a bunch of times. I used to change the oil on fresh engines like as many as five times in the first couple hours. you only have to drop filter and clean it. when the filter is no longer catching anything alarming you can put good oil in and you are ready to go.
Ok, probably dumb question, but how much oil comes out when you take off the filter when the car is full of oil? Or is most of it in the pan because the car is off? Is it as simple as plugging the hole with something?
Just curious as I have never taken a filter off unless the engine was empty of oil.
Old Aug 2, 2015 | 11:20 AM
  #65
kaj's Avatar
kaj
maybe 1/8 of quart or less, i'd estimate. it doesn't take much to fill it up. very little oil comes from the lines, i just dump what's in the filter.
Old Aug 10, 2015 | 01:51 AM
  #66
ace33joe's Avatar
Originally Posted by wreckleford
This is scary. Wix 57092 has bypass valve set at 14 psi, and I have seen lower settings for similar sized filters.
Is this because Kiggly uses 50WT oil or it can happen at thinner oils?
I have seen stock oil pump flows a lot at high rpm, so stock sized filters can become restrictive at high rpm??
Can we use either larger filters (hope that lowers pressure drop) or filters with stronger bypass valve settings like STi? (23 psi for Wix 57712)
I know current Hyundai OEM oil filters are made to be longlife, so their filter media has poor initial filtration efficiency (like 65%) and it gets better as more particles are piling up at the media, the local filter maker said it is fine as clean oil does not have much things to filter anyway.
So if I change the filter frequent enough, I should have pretty good flowing filter. (Also it is dirt-cheap like $2.xx per each locally for Hyundai OEM)
Not sure if I should get something mentioned here.
Do anyone see higher oil pressure after getting the Professional Product filter?
Old Mar 9, 2016 | 08:33 PM
  #67
slipperychicken's Avatar
Waited about a month for 10854, STILL on back order. So I cancelled and bought 10870 instead. Looks like it would work, o-ring dimensions still fall within range of the sealing surface of OFH.
Old Mar 10, 2016 | 09:16 AM
  #68
94AWDcoupe's Avatar
it will fit. but looks like that filter has a bypass.
Old Mar 10, 2016 | 05:06 PM
  #69
I saw that in the description for 10854 as well. But, it didn't make sense since the claim that "no unfiltered oil reaches the engine", was in the same sentence.
I received it yesterday and it looks exactly like the one posted in pic 5.
Old Mar 10, 2016 | 07:59 PM
  #70
94AWDcoupe's Avatar
good to know as that one is a tad longer. I wonder if filter media is longer?
Old Mar 10, 2016 | 08:07 PM
  #71
kaj's Avatar
kaj
I've been out of the loop for a while. Has anyone settled on a which oil filters are the ones to buy? Or does it matter, any more?
Old Mar 11, 2016 | 09:25 AM
  #72
They still classified it as a small filter so the filtration media is the same size as 10854.
Old Mar 11, 2016 | 10:57 AM
  #73
I'm gonna ask a really dumb question.
Regarding the stainless filter, is the process to turn off the car, take the filter off, empty of any material, reinstall the filter and start the car again? I've never started a brand new engine and would rather look dumb by asking this question than not know
Old Mar 11, 2016 | 12:06 PM
  #74
PAdutch's Avatar
I didn't know that no-bypass filters existed but I have always worried about bypassing particles. I do like the idea of filtering 100% of the oil but I would want to be sure to clean the filter element regularly. I was also under the impression that the bypass at initial start-up promoted getting oil to the bearings faster.
I also found Canton filters. They have filters in the right thread:
https://www.cantonracingproducts.com...D-2-58-O-RING/
They also filter down to 8 microns.
Old Mar 14, 2016 | 12:58 AM
  #75
kikiturbo's Avatar
we have looked into this and there are some non bypass filters that can be bought that fit EVO's
there is also a hydraulic oil filter,, that should work
http://www.wixfilters.com/Lookup/Par...px?Part=650740
cheap as chips
