please help dyno results bad!!!
Old Jul 15, 2014 | 06:53 AM
damien666's Avatar
Got my evo iv dynid yesterday has recently been rebuilt if you check my build page on here can see more details its under evo iv sleeper build. Basically has evo 8 block cp pistons forged 85.5mm. And new rings. Balance shaft removed. Acl bearings. Turbosmart boost controller. Yellowjacket coils. Evo 6 ecu.id1000cc fuel injectors. 320lph fuel pump. And usual bolt ons 3inch exhaust ect ect. Did a leakdown test was mint. Did compression test mint 160 160 160 160. Full dyno tune only made 203kw at the hubs on 19psi boost what the hell is going on!!!! It will boost wat its told to it good compression test and leakdown drives awesome feels awesone sounds awesome its reliable done a few 5 hour drives in it. Not to bad on gasbut wont get any mire power to the engine and my tuner a very good tuner its got him stumped also he said best guess be need another block rebuild as rebuilder myst have skimmed to much off top of block or not bored cylibders or honed plz guys im from nz ive spent heaps trying to fix this problem. What could it be?
Old Jul 15, 2014 | 07:38 AM
Faisalm's Avatar
What turbo is on this btw?
I had a hard time following this paragraph, maybe if you can break it down into small paragraphs to make it easier on the eye lol
Also can you request a log for us to see?
Old Jul 15, 2014 | 09:08 AM
egis's Avatar
what dyno and why only 19 pounds?
Old Jul 15, 2014 | 10:31 AM
CT9A PR's Avatar
19 PSI and about 203kw = 270 whp is decent power if you are on an OEM EVo 4 turbo and again only 19psi.
Do you have camshafts? are you running pump fuel?
I suggest turning up the boost and maybe adding timing....Evo 4 turbo are only 9.3 hotside....
Even an Evo 7 turbo with 9.7 hotside would be an upgrade for you but try to get an Evo 6 turbo they have 10.5 hotside
Old Jul 15, 2014 | 11:21 AM
egis's Avatar
that's right ,stock IV pushing 208kw at the engine.so at 19pounds 203 kw it's all good op.
TheRealDirtyDan
May 25, 2017 03:01 PM
mattusmc
For Sale - Cars For Sale
Apr 6, 2016 04:27 PM
szk
Jun 24, 2015 03:30 PM
KevinD
39
Dec 24, 2009 06:42 PM
Chukee_R
Feb 26, 2008 06:05 AM
