Engine ticking noise, new lifters
Old Jul 28, 2014 | 11:49 AM
StefanoIX's Avatar
Hey everyone,
After some track abuse Im experiencing some ticking noise only at idle, as revs goes up the engine noise drowns it out.
The car still performs as always.
I though it was the lifters from what a read here and got new ones installed, but nothing happened.
I would like to hear your opinions
Here is the video:
thanks,
Stefano
Old Jul 28, 2014 | 12:44 PM
leemaster's Avatar
Veteran: Army
I could be your PCV valve, touch it when it's warm and see if the tick is coming from there.
Old Jul 28, 2014 | 06:48 PM
StefanoIX's Avatar
No tick coming from the PCV.
I dont know from where the tick is coming
Old Jul 28, 2014 | 08:08 PM
lownslow's Avatar
sounds like rod knock
Old Jul 29, 2014 | 11:35 AM
StefanoIX's Avatar
maybe its a rod knock
Any more ideas?
Old Jul 29, 2014 | 12:04 PM
Faisalm's Avatar
Yeah that sounds like a rod bearing....
Old Aug 1, 2014 | 06:54 AM
Teal2nnr's Avatar
Pull the oil pan and have a look at the bearings.
Old Aug 1, 2014 | 07:05 AM
Faisalm's Avatar
Yeh... Don't do that at first... look for bronze shavings in the oil and filter before taking of your pan...
Old Aug 1, 2014 | 01:17 PM
StefanoIX's Avatar
thanks guys,
I will check the oil and let u know
Old Aug 1, 2014 | 01:44 PM
meckert's Avatar
Do you have an oil pressure gauge installed? If so do you notice a drop in pressure across the board? If not --then see 'looking at oil" above. Good Luck, I tend to agree--rod knock.
Old Aug 14, 2014 | 03:53 PM
StefanoIX's Avatar
Hey everyone,
Today i took off the oil pan and checked the rods, they are all good...
i found this in the drain plug and i dont know where it comes from, I also took off the valve cover to check, but nothing...
Does someone know what it is?
Old Aug 14, 2014 | 04:03 PM
loch's Avatar
Looks like piece of a retainer
Old Aug 14, 2014 | 04:36 PM
Bhsj13's Avatar
oooooo, looks painful! yeah looks like a retainer.
Old Aug 14, 2014 | 05:38 PM
StefanoIX's Avatar
Its not a retainer.
Old Aug 14, 2014 | 06:23 PM
Biggiesacks's Avatar
did you check cam timing? Maybe jumped a tooth.
evolord21
Dec 1, 2015 10:53 AM
boostin gsr
Nov 27, 2015 01:34 PM
Spoolin4g63
Jun 17, 2015 09:43 AM
Hainec82
Oct 14, 2014 05:29 AM
kyracer1989
Dec 31, 2012 12:43 PM
