lifter tick?
Old Oct 21, 2015 | 01:26 PM
boostin gsr's Avatar
lifter tick?
so i have this ticking noise coming from my engine. i was told its lifter tick but it is louder some days then it is others. what should i listen for/check to make sure it isn't rod knock.
ill try and post a video of the noise a little later when i get a chance.
Old Oct 30, 2015 | 02:48 PM
wheatbix's Avatar
Lifter tick should go away after the engine has warmed. Also it's a definite ticking noise, as opposed to other engine issues which can either be felt at the same time and/or more likely to increase / decrease in volume with engine speed.
If yours is louder some days then others I'd say it is lifter tick, and the difference is just the outside temperature. Only way to know for sure would be to get a compression check and / or pull your lifters and have them cleaned.
Old Oct 30, 2015 | 03:03 PM
Im new to uploading videos on here. Im trying to upload from my phone but the video is to big it says. It's a 7 second clip only
Old Oct 30, 2015 | 05:20 PM
I made a photobucket. How can i upload it?
Old Nov 21, 2015 | 09:38 PM
Teal2nnr's Avatar
The 4G has loud lifters. Regardless if the car is warm or cold they will tick. When a lifter goes you will hear it....its EXTREMELY noticeable. They're very easy to change out with the specialty tool, so it might be worth slapping some in if you're worried about it.
Old Nov 21, 2015 | 10:01 PM
Any recommendations for what kind i should get
Old Nov 21, 2015 | 10:17 PM
Teal2nnr's Avatar
I use the GSC 0 tick lifters (they still sound the same though). They have a stiffer internal spring then the stock ones. You can also use the big bore 3G lifters, they're a bit cheaper and the same as the ones that come in the Evo's.
Also the lifter specialty tool makes life easy when changing them. You also can just use a flat head screwdriver if you don't want to buy the tool.
https://www.rtmracing.com/xcart/prod...roductid=17917 Tool
https://www.jacksonautomachine.com/b...e-liftershlas/ Lifter (3G)
http://www.power-division.com/produc...cat=304&page=1 Lifter (GSC)
Old Nov 23, 2015 | 10:49 AM
How do i post a video to here? Before i buy lifters
Old Nov 27, 2015 | 01:34 PM
Teal2nnr's Avatar
Just upload it to youtube and post the URL I suppose.
PVD04
18
Jun 25, 2012 01:20 PM
thedru13
Apr 5, 2010 08:39 AM
blackoutVIII
Dec 3, 2007 12:56 PM
coolguycooz
Sep 22, 2006 05:43 PM
SlowCar
34
Dec 9, 2005 03:04 PM
