Want to get close to 400hp out of my evo 8...!!
What did cbrd set boost at when you made 310 on the dyno? On stock fuel pump with injectors at 1000% duty cycle, I can only run 16-18lbs before it run in the 11.6-12.5 afr range which I know is lean for the stock bottom end. I am going to install a w255 next week and hopefully that helps
The_X_Effect
30
Aug 20, 2016 08:27 PM
mct9891
34
Jan 29, 2015 10:31 AM
