Greddy LS Spec IC Kit Evo 8 - 9 differences
Old Aug 22, 2014 | 10:10 PM
french's Avatar
I am looking at buying the Greddy LS Spec IC kit. Only issue I am having is there is two separate kits for evo 8 and 9.
Whats the difference?
I ask because I have a 8 with a 9 turbo.
Old Aug 23, 2014 | 12:32 PM
slowsrt4:('s Avatar
I would assume that the end tanks for the 9 would be wider, similar to the ETS version of the 8 and 9 intercoolers they offer.
Old Aug 23, 2014 | 12:37 PM
TommiM's Avatar
likely what slowsrt4 said. If you pick one of these up post up some pics of the internal fin designs inside the core, and some installed pics. You dont see too many of these intercoolers out there.
Old Aug 23, 2014 | 12:53 PM
deylag's Avatar
The reason why ETS made two different intercoolers was because of the difference of the 8 bumper to 9 bumper. The 8 bumper has a wider opening while the 9 bumper has smaller opening. So they designed the end tanks for the 8 to smaller because they could fit a bigger intercooler core.
Old Aug 23, 2014 | 02:51 PM
french's Avatar
Cheers guys. I will post some pics up if i end up getting one.
Old Sep 4, 2014 | 02:52 AM
french's Avatar
I received the kit today. I am a little concerned as i probably should have elaborated the kit includes both hot and cold side piping , with the hot side connecting directly to the turbo. I am planning on upgrading the turbo from stock 8 turbo to a 9 when i install the ic kit.
Should i be worried about fitting the evo 8 kit to the evo 9 turbo?
Old Sep 4, 2014 | 08:32 AM
JohnBradley's Avatar
That will be the same. The outlet pipe off the turbo is different but the geometry change isnt enough to require a specific pipe.
Old Jan 27, 2015 | 02:21 AM
french's Avatar
Old post but anyway. The outlet for the turbo that came with the kit did unfortunately hit my starter motor.
The rest of the kit was fine though.
Damian8MR
Aug 17, 2016 10:28 AM
kjcs9
Jun 5, 2016 01:22 AM
Appauldd
Nov 9, 2015 12:07 PM
d-bo
Aug 24, 2015 08:30 PM
07EvoIX
Oct 28, 2012 12:49 PM
