FP Green on stock internals?
Old Sep 15, 2014 | 08:08 AM
Thrilla's Avatar
Veteran: Army
Stock internals
I have a similar setup. I have a bbk full with stock internals. Like everyone stated, keep the torque below 400 and it should be fine.
Old Sep 15, 2014 | 05:16 PM
EvoTurboTurk's Avatar
Originally Posted by michaelrc51
It is all about the torque.
Does the small turbo produce more torque down low, which effects the stock internals?
Old Sep 26, 2014 | 04:34 PM
Also what is equivalent or close to a FP Red Ball Bearing from the Garrett turbo range?
Old Oct 5, 2014 | 01:50 PM
Ang Wen Yan's Avatar
Yes
Small turbo tend to have peak torque very early and your OE rod does not like that
Rule of thumb is ~400ft/lb or so for stock internal car(Dynojet #)
A FP Red is probably equal to something like GTX3071 or GTX3076 power wise
Old Oct 5, 2014 | 04:49 PM
Originally Posted by Ang Wen Yan
Yes
Maybe a silly question but is 400ft/lb towards the wheels or engine?
Old Oct 6, 2014 | 04:07 AM
Wheel
Since you are based in aussie,there are plenty of EVO specific shop,talk to them and i am sure they will tell you what to do
Old Oct 9, 2014 | 01:54 PM
Jhurley_EvoVIII's Avatar
I love my FP green... its the old version though... i'm making 425whp/385wtq stock motor with a rebuilt head with springs, cams, retainers, lifters, etc. Its a FANTASTIC turbo. I highly recommend it.. And in terms of stock motor... 400wtq is where tuners decide to cap 4g63 AND 4b11t... its all in the toon I track the living hell out of my car and it hasnt failed me yet
Old Oct 11, 2014 | 08:10 PM
Yes
I always thought a FP Red Ball Bearing would be somthing like a gt35, maybe I mixed up.
Old Oct 12, 2014 | 12:24 PM
420a-t's Avatar
3582 is almost identical to an fp black.
I made 506whp on the green stock engine with the exception of comp 280 cams and a kiggly hla.
All about keeping the spoolup curve and max torque down via timing, afr's, and ecu controlled boost.
Old Oct 12, 2014 | 08:45 PM
good #'s stock block... if you have a smooth progressive torque curve you should be fine!
Old Oct 19, 2014 | 04:41 PM
ElectricBlueIX's Avatar
Is there any major difference between the FP Green and the BBK Full ported?
Old Oct 20, 2014 | 03:26 AM
nzevo8's Avatar
how would a fp green compare to a fp red on the stock internal ?
which turbo would be the more effective turbo for the stock block ?
Old Oct 20, 2014 | 04:40 PM
jlucasgsx's Avatar
Bird seed!
fabiano
14
Dec 17, 2015 04:42 AM
foxracing515151
Aug 6, 2014 12:32 PM
JdmSyndicate
71
Aug 19, 2008 09:32 PM
voidhawk
Apr 4, 2008 01:13 PM
SurferX
14
Jan 15, 2008 01:59 PM
