Car wont free rev past 3k
Old Oct 3, 2014 | 07:34 PM
Grimgrak's Avatar
It just goes lean and misfires. Car is SD tuned.
Car was boosting fine but had a fuel pump issue with hot starts.
Turns out it was my external pump (ams surge tank) verified this by tapping the surge tank when the idle started to go lean/die. Tapping it fixed it.
Replaced the pump now it wont free rev past 3k. Hot starts great now tho :O
Tps wont read past 50% floored while misfiring. However with the car not running but key on it will read 99.9%
Old Oct 4, 2014 | 04:52 PM
mt057's Avatar
Vale mode? I see you said you had it floored while the key was in and on...Hope it is something simple.
Old Oct 4, 2014 | 11:51 PM
Grimgrak's Avatar
The CEL does blink(flash quickly) at me for about 3 seconds before it starts but goes away and shows no engine codes when i do a dtc scan. I seem to recall it being solid in the past without the flashing but I could be wrong.
Found out sparktech charges 25$ to bench test a ign box so might send it in....
Old Oct 5, 2014 | 08:52 AM
wreckleford's Avatar
Check if your tank is rusty. Debris will block the fuel filter/damage the pump and cause this behavior (assuming it also runs lean while driving). Just went through the same issue with a car last week.
Old Oct 5, 2014 | 10:23 AM
mt057's Avatar
Turn the key to the on position. Hold the gas pedal to the floor for ten seconds then release the pedal. Turn off the car and turn it back on. The cell should blink slowly. You are out of valet mode and you should be free to drive again. Hope that works.
Old Oct 5, 2014 | 11:06 AM
Grimgrak's Avatar
How do you put it in valet mode in the first place? lol
Old Oct 5, 2014 | 11:22 AM
VanduzerWilliam's Avatar
You just need to turn the key to on, put gas pedal down for 10 seconds like they said, this triggers valet mode in thepra..
Just repeat and its out.
Old Oct 5, 2014 | 06:37 PM
Grimgrak's Avatar
Well that was the trick... either that or disconnecting the battery. Car drives great now.
Old Oct 6, 2014 | 07:16 AM
llDemonll's Avatar
Is this something built into the stock ECU? Never heard of it before
Old Oct 6, 2014 | 09:50 AM
mt057's Avatar
It is part of the Tephra mods. It would be awesome if it was stock.
Old Oct 11, 2014 | 11:11 PM
Atomic646's Avatar
lmao
CT9A PR
May 27, 2014 10:56 PM
manthny18
Mar 31, 2013 04:45 PM
Aliengotpsi
11
Jun 13, 2012 06:09 PM
TougeTuned00
Lancer Troubleshooting
Mar 7, 2012 01:31 PM
Apex Buddy
10
Sep 20, 2005 03:04 PM
