How long is your dipstick? Evo 4-6.5 - Help
Old Nov 10, 2014 | 08:44 PM
EvoAlexP's Avatar
Question How long is your dipstick? Evo 4-6.5 - Help
So, we did a head gasket on a mates evo 4 which apparently has the 6.5 motor in it, looking at the thermostat housing etc also indicates it may be a genuine motor. however on reassembly the dipstick is nowhere to be found.
have bought a replacement dipstick from a mitsi wreckers but it is for an evo 7 apparently.
After filling the car with the correct amount of oil according to the fsm the new dipstick reads about 5cm above the full mark.
I suspect that its the wrong stick eh. Could anyone please whip out to their car, measure (from the bottom of the white plastic) to the high oil mark, the low oil mark & the bottom of the stick -(please also state the engine you are running, 4,5,6,6.5 so i can see if they are the same. and i will just trim this bad boy to length. don't want to start the car until i am 100% the oil level is right.
Thanks heaps, Alex.
Old Nov 11, 2014 | 06:11 PM
TommiM's Avatar
Have you started the car up at all? If you pour in the specified amount it will read higher as that oil hasnt flowed through the oil filter, oil cooler, etc. If you poured in the correct amount and ran it and then rechecked and the level is good then you should be fine.
Old Nov 11, 2014 | 06:46 PM
silverevo05's Avatar
mine is 2 inches
from the ground
Kevin Knight
Nov 26, 2016 08:56 PM
karwh0re89
Dec 9, 2012 03:29 PM
Kemist
Mar 1, 2009 03:33 PM
epson1
14
Sep 14, 2008 08:33 PM
SuperchargedGTZ
27
Sep 10, 2004 11:21 PM
