Please help radiator leak
Hello all,
I have a 2006 evo 9 with about 90,000 miles on the clock.
Today when I was checking the oil level I noticed the overflow was empty and that the radiator was leaking from the top.
I think it may be due to the 1.3 bar ralliart radiator cap I put on a month ago from japanparts.
I am now going to top off the radiator and burp the system after the car cools and put the oem cap back on and see if that fixes things for now.
Any suggestions on upgraded radiators (yes I searched a lot) CBRD is nice but is not a bolt on and is pricey. Koyo has had many accounts of leaking. So Mishimoto looks like the winner.?? I am not crazy about the mirror finish and the logo on top of the radiator… Living in Kalifornia that is more of a reason to go to the smog ref. Is there a high quality bolt on radiator without the bling?
If Mishimoto is the way to go which vendor can get it to me fastest in socal?
Thanks,
Nick
Thanks,
Nick
Ok just checked the car, radiator was still full of coolant still. I replaced the cap back to the oem 1.1 bar cap. Will go for a short drive and see if it leaks.
I understand the oem system was designed to only have 1.1 bar of pressure but if only an extra .2 bar of pressure makes the radiator leak from the seams, that is something I would want to upgrade anyways.
If it is leaking from the seams then the radiator is bad. Factory radiators are prone to leak where the end tanks meet the core and when they do they will continue to do so till it blows. Your best bet is replace the radiator as soon as possible. I really think the Mishimoto radiator is the best bet. I have seen both Koyo racing and the Fluidyne radiators leak where the end tanks meet the core but I have not seen that happen on the Mishimoto radiator. It even a lot cheaper then the other 2. All 3 of those radiators have been on a Supra and the only one that is still good today with no leaks is the cheaper in price Mishimoto. Good luck to you and I think you should check out Amazon to see if they can get the radiator out to you in a day or so.
Go with Koyo, it's better quailty then Mishimoto. Almost ever quailty shop will recommended Koyo. I just bought a Koyo, my stock Radiator is leaking from bottom where the metal is crimped to the plastic. CBRD is nice, problem is I want to keep stock fan and it won't bolt like factory. I am from Nor Cal and know the pain of the cops around California, I don't think a radiator would be considered illegal.
Hello all,
Thanks,
Nick
Thanks,
Nick
Thanks for all the replies!
I pulled the trigger on the Mishimoto yesterday. A vendor from this website had it in stock and since I need this asap, thats what I went with.
While the radiator is not illegal, it will definitely help you to get smog reff'd by a cop especially if you have other questionable things going on. Just too much bling!!!… I think I may research some steel wool to use to dull the finish… Any suggestions on grit??
Also not to be a hater, but Mishimoto isn't in my mind a high quality brand. But it seems that they are changing that. IDK
There is good feedback on the part and a lifetime warranty!
nlp187
Jul 8, 2012 10:32 PM
Boost3dxEvO
Jul 26, 2009 08:51 PM
