GSC S2 Cams - What is your Cams Setting Spec?
Old Nov 24, 2014 | 08:21 AM
jameswwt's Avatar
Hi, would like to know what is your GSC S2 Cams Setting/Dialing (Advan & Retard) on their Exh & Intake cams.
Pls share
Old Nov 24, 2014 | 10:11 AM
GTijoejoe's Avatar
42 people had viewed this, I bet 50/50 are either WTF is he asking, and the others just curious..
Cam setting spec?
I imagine you're either asking about the actual tuning map or adv/retard of a cam gear(s)?
You should specify so someone can actually answer your question.
Good luck.
Old Nov 24, 2014 | 11:18 AM
Sil'vr-Boi6's Avatar
I am curious...how much hp or driveablity am I missing without properly dialing the cams?
if not much, is hp/driveability more evident as power climbs?
Old Nov 25, 2014 | 05:49 PM
kpr's Avatar
kpr
Most Evo cams are installed at 0. Advance/retard cam gears is usually a fix for an improperly ground cam. GSC are very good.
There are other cases that my need adjustable cam gears, 4g64, block/head were surfaced a lot. things like that but usually no adjustable gears are needed.
Old Nov 26, 2014 | 01:33 AM
jameswwt's Avatar
Hi KPR, thanks for sharing and my head and block deck have been skim 0.20mm.
Yes, im using adjustable cam gears.
Im now building 2.3L stock head & block with 4G64 crank (100mm), Wiseco 8.5.1 + BC Ibeam rods.
Do i still degree the cams as per GSC cams spec?
Old Nov 28, 2014 | 03:43 AM
jameswwt's Avatar
My head and block deck have been skim total of 0.20mm.
Old Nov 28, 2014 | 05:21 PM
okevolutionVIII's Avatar
They have tested S2 cams with cam gear and found that dialed 0/0 with a degree wheel according to the cam spec card was the best overall performance.
Old Nov 29, 2014 | 12:30 AM
jameswwt's Avatar
Old Nov 29, 2014 | 05:06 AM
Ted B's Avatar
The GSC cams are timed very intelligently right out of the box for street/strip applications. There is little need to invest in cam gears unless perhaps one has a stroker engine in a dedicated track car, and wants to squeeze every last bit of power from it.
Old Nov 29, 2014 | 05:32 PM
jameswwt's Avatar
Thanks Ted B for sharing.
maxspeed96ct
Sep 4, 2016 05:50 AM
jameswwt
Mar 21, 2011 05:27 PM
jameswwt
Oct 22, 2010 04:45 AM
jameswwt
Oct 18, 2010 05:36 PM
jameswwt
Sep 7, 2010 10:28 AM
