Eagle rods in 2.3
Old Nov 24, 2014 | 02:40 PM
mr evo7's Avatar
Eagle rods in 2.3
Hey guys. Whats the most eagle rods have been pushed to. Specifically in a 2.3 stroker
Old Nov 25, 2014 | 11:16 AM
JohnBradley's Avatar
590 ft lbs in one of our motors, I presume someone has done more in others. I have done 630 ft lbs on H beams in general and anything over the 590 we recommend I beams.
Old Nov 25, 2014 | 11:58 PM
mr evo7's Avatar
Ok awesome thank John
Old Nov 26, 2014 | 01:36 AM
EvoTurboTurk's Avatar
I beam can handle more ft lb then H beam? I wonder why summit claim H beam is more stronger the I beam?
Old Nov 26, 2014 | 08:41 AM
No rod manufacturer I know claims that H beams are stronger than I beams. Lighter yes, stronger no.
Old Nov 26, 2014 | 02:06 PM
http://m.youtube.com/watch?v=fszNIRbS8yw
@4:40 seems like he says I beam is good for stock or moderately modified vehicle, however if you want to make more horsepower the H beam is where to go.... In a way according to them, they claim H is stronger then I? Or I'm still understand wrong, I may do 2.3 & want to make sure I have stronger rods.
Old Nov 26, 2014 | 02:49 PM
LetsGetThisDone's Avatar
Going from an OEM I-beam (which is typically powdered metal these days.), to an aftermarket H-beam is an upgrade. However, an aftermarket I-beam rod is typically stronger than its I-beam counter part.
Old Nov 27, 2014 | 12:49 PM
SiriusEvo's Avatar
Veteran: Army
I windowed a block with H-beams and ~600ft/lbs on a 2.4
I had it at 500ft/lbs for a long time but as soon as I got close to 600 it was a wrap.
Old Nov 27, 2014 | 09:32 PM
mr evo7's Avatar
Wat brand of rods did you have?
Old Nov 28, 2014 | 12:08 PM
SiriusEvo's Avatar
Veteran: Army
Manley H-beam
Old Nov 29, 2014 | 05:37 AM
Ted B's Avatar
Anyone who intends to make a 4-cyl engine generate 500+ ft/lb through a set of rebranded Chinese H-beam rods (e.g. Manley, Eagle, BC, etc.) I regard as one who likes to gamble.
Old Dec 1, 2014 | 01:43 PM
mr evo7's Avatar
In short will my eagle rods handle what my PTE 6262 (0.82AR ) is gonna throw at them
Old Dec 1, 2014 | 02:23 PM
SiriusEvo's Avatar
Veteran: Army
I would still do the I-beams.
Like Ted mentioned above, I "gambled" with those rods but It was a spare block I used for the winter (when I used to DD the car). I kept upping the boost until it finally gave.
You have to take in consideration that we dont live in a perfect world and if one thing goes wrong and combustion pressure spikes thsoe rods will be the weakest link.
evovin
41
May 26, 2008 03:24 PM
2k4EvoVIII
11
Apr 25, 2005 07:03 PM
EVOVII_SWE
12
Sep 17, 2004 09:51 PM
94AWDcoupe
Sep 2, 2004 06:14 AM
