Wiseco 2.3L Piston Ring Gap - Need Advise
Old Dec 1, 2014 | 04:36 AM
jameswwt's Avatar
Hi, would hope to get some advise here on my Wiseco 2.3L Piston Ring Gap.
The feeler gauge reading on Top Ring 0.17 (431) / 2nd Ring much bigger than what my feeler gauge have (more than 0.20 (508) above and im confuse as the wiseco ring gap spec for Street Moderate Turbo recommendation for Top Ring is 0.0050" inches / 2nd Ring is 0.0055' inches
Piston Bore Size : 86mm / 3.3858 inches
Wiseco Ring Gap Spec :
Top Ring = 0.0050" x 25.4mm = 0.127mm
2nd Ring = 0.0055 x 25.4mm = 0.140mm
So, my concern is the currently ring gap (Top & 2nd Ring) is already very much bigger than the Wiseco recommended ring gap spec.
My NOOB calculation : Since the required spec as mentioned is 0.0050", So bore size 86mm = 3.3858" x required gap size for my application 0.0050" = Required Feeler Gauge Reading is 0.17?
Please forgive and teach me on how to correctly read the Feeler Gauge & Calculation.
Thanks A Million
Attached Thumbnails Wiseco 2.3L Piston Ring Gap - Need Advise-ccf12012014_00000.jpg   Wiseco 2.3L Piston Ring Gap - Need Advise-1.jpg
Old Dec 1, 2014 | 10:43 AM
LetsGetThisDone's Avatar
Your caliper is reading in MM, which is literally right at .017".
I would shoot for .018" top ring, .020" bottom ring. Maybe a little more depending on how much boost you're going to run.
Old Dec 1, 2014 | 04:55 PM
jameswwt's Avatar
Hi, thanks for yr kind advise and so im right on the calculation as Feeler Gauge 0.17 (431) is equivalent to 0.0066"
If according to Wiseco ring gap of 0.0050" the Feeler Gauge reading is 0.13 (330)?
Secondly, my 2nd ring gap is more than 0.20 on the feeler gauge and will this cause problem?
Old Dec 2, 2014 | 03:50 AM
jameswwt's Avatar
Anyone mind to advise?
Thanks
Old Dec 2, 2014 | 04:56 AM
evolve_VIII's Avatar
How much power do you plan on making? What turbo and what boost levels? That will come into play when doing a build.
I set mine to .022" top and .024" bottom. Running almost 40psi on this setup.
Old Dec 2, 2014 | 07:36 AM
jameswwt's Avatar
Hi Evolve, im only looking at 22psi boost and going for 0.0055" on Street performance and Occasionally Track & Hill Climb run.
Targeting 370whp.
Whether will it be a Ok if the Top ring gap is .017" and 2nd ring is .022"?
My 2nd ring gap is more than .20" now.
Thanks
Old Dec 2, 2014 | 08:32 AM
Targeting 370whp.
Thanks
your ring gap is not .20", you would be able to measure that with a measuring tape. Those gaps that wiseco recommends (.0055, .0060, etc) need to be multiplied by the bore (in inches).
if you get your ring gaps at .018"-.020" top ring, and .020"-.022", you'll be fine. The important thing is for all the ring end gaps to be as close to the same as possible.
Old Dec 2, 2014 | 08:51 AM
jameswwt's Avatar
Hey, Thanks for your advise and what do you think if i only go for 0.16" top ring and 0.22" 2nd ring?
Old Dec 2, 2014 | 10:20 AM
Open the top ring up to .018"
Old Dec 2, 2014 | 04:40 PM
jameswwt's Avatar
Old Dec 3, 2014 | 07:40 AM
jameswwt's Avatar
Dear Forumers,
could you advise me on how do exactly install the Groove Lock Spacer which comes with the Pistons?
Is it to be place on the bottom most at the Oil Rings groove?
Example :
1 - Top most = Oil Rail
2 - Middle = Oil Ring Expander
3 - Direct below Oil Ring Expander = Oil Rail
4 - Below Last Oil Rail = Groove Lock Spacer
Is the sequence correct and what if the Groove Lock Spacer Ring is not install?
Thanks
Attached Thumbnails Wiseco 2.3L Piston Ring Gap - Need Advise-1.jpg   Wiseco 2.3L Piston Ring Gap - Need Advise-2.jpg
Old Dec 3, 2014 | 12:22 PM
Targeting 370whp.
Thanks
As long as the second ring is larger you are ok. For that, I would do .018-.020 on the top and .022 on the bottom.
Old Dec 3, 2014 | 04:54 PM
jameswwt's Avatar
Thanks Evolve and can you advise me on the placement of the Groove Lock Spacer Ring as well.
Old Dec 3, 2014 | 04:55 PM
jameswwt's Avatar
Dear Forumers,
Example :
Thanks
Please kindly advise
Old Dec 4, 2014 | 12:53 PM
yes, groove lock spacer should be on the very bottom.
