Evo 9 transmission swap problems
Old Dec 3, 2014 | 05:04 PM
fast3voviii's Avatar
I recently swapped a new Evo 9 transmission into my Evo 8.
The car does not move with the clutch pressed in. It does shift gears properly at idle with the clutch in.
But the problem is the car will also move forward in neutral if the clutch is released.
Is there something in the linkage that needs to be changed or is the transmission bad?
I've never seen this happen. I've had it move no matter if the clutch is in or out due to the twin disk being installed improperly.
Help please
Old Dec 3, 2014 | 10:15 PM
ReidFletcher's Avatar
Read your post wrong. Doesn't sound like a clutch issue.
Old Dec 4, 2014 | 04:56 AM
Update: we've tried it with the shift linkage unhooked and the trans in neutral. Still does it
Only thing that comes to mind now is since I brought the transmission used and it was dry, something inside is sticking due to friction
Old Dec 4, 2014 | 07:32 PM
Anyone?
Old Dec 4, 2014 | 09:58 PM
94AWDcoupe's Avatar
that sounds like a trans problem. try driving it t see if it loosens up. if not it needs to be opened up.
seankhan
49
Nov 26, 2019 01:43 AM
pilotage1111
Aug 12, 2015 09:38 PM
evo854880
Sep 5, 2013 05:56 AM
maknuge
19
Dec 7, 2012 02:19 PM
Ghost76
10
Jan 22, 2010 06:52 AM
