Carrillo H beams vs turbo tuff I beams
Old Dec 15, 2014 | 10:51 AM
Ted B's Avatar
The A and SA are A-beams, not H-beams. Their H-beam is their strongest off-the-shelf rod.
Old Dec 15, 2014 | 05:49 PM
FlaEvolution's Avatar
I ended up going with their most expensive H beam Carrillo offers with the Carr bolts as well. Car will be a mid 800whp car all said and done.
Hopefully all is well with this choice.
Old Dec 17, 2014 | 08:44 AM
DRAG's Avatar
Which version? They offer three versions of the rod. They increase in price with strength. Pro A, Pro SA, and Pro H...
They shouldn't even offer a Pro A for an EVO. THEY rate them at 75bhp per cylinder. I have a box full of Honda Pro As from guys who didn't believe that
Old Dec 17, 2014 | 08:45 AM
DRAG's Avatar
You will be fine. Its a good rod for that. Only run the Pro H for anyone else reading. The Carr bolts are real nice, but their base bolt holds up no issue if you wanna save a buck.
Old Dec 17, 2014 | 09:22 AM
LetsGetThisDone's Avatar
I didn't realize they were a-beams, and that weak lol. The one place that sells them still pictures an h-beam rod..
Old Dec 17, 2014 | 09:53 AM
Ted B's Avatar
I'm fairly certain that Carillo's A-beams are in fact the same rebranded Chinese rods I've seen on China based websites, a la Eagle, Manley, Brian Crower, K1, etc. Almost everyone has a budget option these days to stay competitive. When it comes to a turbo engine generating 250+whp/L and similar torque however, the rods are perhaps the worst possible place to go cheap.
Old Dec 17, 2014 | 12:14 PM
94AWDcoupe's Avatar
the A beams are non rebranded chinese rods. they are a very nice billet rod. simply not designed for turbo use. it was designed for n/a.
Old Dec 17, 2014 | 12:22 PM
CT9A PR's Avatar
A respected puerto rican tuner once told me carrillo have a life time warranty and their bolts are top quality
Old Dec 17, 2014 | 12:53 PM
Ted B's Avatar
I've read conflicting reports about this, so I contacted Carrillo about it. You are correct. Both the H and A beam rods are actually made from the same forgings. The difference is machining and design.
Evidently, the familiar looking Chinese A-beams are Carrillo knock-offs, hence the speculation.
They warranty the integrity of the rod itself (e.g. quality of steel and proper size).
Old Dec 17, 2014 | 08:04 PM
EvoTurboTurk's Avatar
How would I beam go in terms of reving up to 9,000rpm?
Old Dec 18, 2014 | 02:33 PM
depends on which rod. A stock I beam will likely come apart with prolonged use. An R&R or manley TT would be fine..
Old Dec 24, 2014 | 09:10 PM
Still waiting on the rods to show up. Plan on posting some pictures of them when they do.
Crank and everything that can be assembled has been done.
Probably delayed shipping due to the holidays.
Old Mar 18, 2018 | 02:33 PM
2006EvoIXer's Avatar
What ever happened to this thread? Do we have results? Did these rods pan out?
Old Mar 19, 2018 | 08:15 AM
The Carillo Pro-H is a badass rod. I would choose it every time over a Manley I-beam. Lighter weight with plenty of strength.
Old Mar 19, 2018 | 10:41 AM
What pistons and rings goes best with Carrillo rods?
