Replaced bushings still have same problem. Whats next?
Old Dec 6, 2014 | 09:20 AM
IggyBcool's Avatar
A few months ago when I first got my car, the shifting felt great on it. I would notice that when I would go to hit third hard, it would feel "mushy" and it wouldn't be in gear so I would go back to neutral then go back in to third and it would take it.
However, last week, I noticed it starting to do it to first when backing out of my driveway, when I would go to shift in to 1st, it would just "go and feel mushy" and you would have to push a little harder and you could feel it go in to gear. Now its doing it consitently to 1,3,5 but 2,4,6,R all feel crisp. Its kind of baffling because while sitting still, you can push the clutch in, put it in gear like you're about to move and it will feel like I said loose and mushy, but if you slowly put it in gear and go to 2nd, 3rd, or what ever, it feels tight again, but as soon as you go to actually put it in gear like you were having to move, it goes back to that mushy feeling.
I replaced my base and underhood bushings, it didn't make any difference. What is next to look at replacing?
Old Dec 6, 2014 | 11:50 AM
LetsGetThisDone's Avatar
check that the cable housings are tight where they attach to the shifter base and the bracket on the trans.
Old Dec 6, 2014 | 12:03 PM
MR. EVO MR's Avatar
Instead of going into neutral, Does double clucthing work?
Old Dec 6, 2014 | 02:42 PM
IggyBcool's Avatar
It's difficult to explain.. it feels like something is either loose or has "wallered" out. When just sitting and playing with the gears you can usually get it to go right in with a crisp firm feeling, but as soon as you start driving, it feels free and like I said mushy then you have to either push further for it to take gear, or you have to go back to neutral and try again. Then sometimes you can get it to do it sitting still in like third and you can actually feel the slop/play move about half an inch snd you can hear distinct sound of unnatural moving, not like a grinding noise but rubbing. Only does it on 1,3,5.
Apr 4, 2013 09:14 PM
600RR
Aug 16, 2012 05:24 AM
revvin9k
19
Jul 11, 2009 05:18 AM
Henster
May 7, 2008 09:07 PM
