Subframe trimming for tranny installs
Old Dec 17, 2014 | 09:01 AM
tsitalon1's Avatar
Has anyone slightly trimmed the subframe corner where the tranny likes to get hung up on during installs?
Seems to me trimming this 1/2 lip in the trouble area would make install a lot easier.
Old Dec 17, 2014 | 09:20 AM
LetsGetThisDone's Avatar
I just take the steering column off the rack from inside the car, and then the subframe moves out of the way nicely..
Old Dec 17, 2014 | 09:41 AM
heel2toe's Avatar
I know exactly what you are talking about and all it would take is just a smidge. I'd just be hesitant to start grinding away at the subframe although Ive already cut into mine in the past thanks to seized LCA bolts.
If you have the cash the best option would be to pick up one of those trick lightweight subframes. Not only would you shed weight there would be some much more room in there and would make dropping the trans a breeze.
Old Dec 17, 2014 | 01:24 PM
tsitalon1's Avatar
I've thought about that but was unsure of the amount of work involved.
How do you avoid alignment issues this way?
Also if the column is all you're disconnecting, how far does the subframe actually move?
Old Dec 17, 2014 | 01:26 PM
tsitalon1's Avatar
Well, we are only talking about grinding about 2-3 inches along that edge, I wouldn't think that would drastically affect subframe strength.
Old Dec 17, 2014 | 01:27 PM
foxbear2277's Avatar
Just lowering the sub-frame a bit has always worked great for me.
Old Dec 17, 2014 | 02:17 PM
no alignment issues, its a splined shaft. Granted, you should get an alignment done whenever you drop the subframe. Just make sure the steering wheel is locked centered. It then moves as far as the power steering lines allow it to, which is quite a bit..
Old Dec 19, 2014 | 04:56 AM
Lexus01IS's Avatar
I cut mine out
Old Dec 19, 2014 | 02:25 PM
tsitalon1's Avatar
Originally Posted by Lexus01IS
I cut mine out
Sweet, any adverse affects?
Did it make it much easier to get it installed?
Old Dec 24, 2014 | 05:09 PM
Lexus01IS's Avatar
It still sucks but gives u little more room. Otherwise no other effect.
Doug88
Jun 29, 2007 08:56 PM
tlcoll1
Aug 1, 2006 04:36 PM
Thoe99
13
Sep 30, 2003 03:22 PM
neilschelly
19
Jun 13, 2003 07:02 AM
