Solid Street/Strip Turbo for New Build?!
Old Jan 8, 2015 | 02:09 PM
Frasch's Avatar
Motor is getting rebuilt this spring and will be converted to a 2.0LR set up with the following parts:
Manley Turbo Tuff I Beams - 156MM
Weisco Pistons 1400HD 2.3L - 9:1CR
ACL Race Bearings
ARP Main Studs
Supertech Valves - std size
Balance Shaft Elimination kit
Parts already installed on car:
GSC s2 cams - 274/274
Ported Stock Ext Manifold
L19 Headstuds
UICP/LICP
Tial BOV
SD Intake
3" FMIC
1000 PTE Inj
DW 300LPH fuel pump (do have a walbro 255 if needed to swap)
Was looking at more of a stock frame turbo such as the new FP Zero/Zephyr but now branching out to an idea more of a t3/t4 setup? Goals would like to be 400-500 on 91oct and 600 on e85. Thanks
Old Jan 8, 2015 | 02:55 PM
LetsGetThisDone's Avatar
FP red will handily reach those goals for you and reach full boost under 4500rpm.
You're going to need a walboro 450 and FIC1650's to make 600hp on E85..
Old Jan 8, 2015 | 03:25 PM
Bhsj13's Avatar
fp red/black will do plus fueling.
Old Jan 9, 2015 | 01:37 AM
vaflyboi757's Avatar
If you're think about T3's, get a HTA82/HTA86, something along thoughs lines. And upgrade to a double pumper and bigger injectors.
Old Jan 9, 2015 | 09:18 AM
FP red or black will outspool both of those and make 600 on E..
Also, OP, I would run the stock valves if you're not going oversize and they aren't worn out..
Old Jan 10, 2015 | 01:16 PM
okevolutionVIII's Avatar
A PTE 5858 will get you 500 on 91 and 600 on E85.
TURBO_S2K
May 19, 2013 09:14 PM
Sales@ACT
Sep 9, 2008 10:39 AM
sawgunner06
Sep 3, 2008 07:45 PM
