Evo 8 missing sounds like a Subaru. Need help!!
Old Jan 12, 2015 | 03:35 PM
4bangn's Avatar
Originally Posted by kaj
If the car was dying while coming to a stop but then return to normal I would say it could be the diverter valve. Since you have larger injectors, it really sounds like your BISS is out of adjustment. Mine used to do the same. The setting should be addressed any time you change injectors. Your tuner should have done this, but not all take the time.
And yes I just mean a recirculating valve is okay but one that vents to atmosphere makes MAF cars run poorly.
diverter valve: where is that and what is a BISS???
Old Jan 12, 2015 | 05:01 PM
kaj's Avatar
kaj
Originally Posted by andrewzaragoza
If it is 12.8 at idle or normal driving you probably have a boost leak as well.
Actually idle and cruise are vacuum and run closed loop from the O2 sensor. The ECU would compensate. Fuel trims would be way off, though. Under boost, in open loop, it would run rich, though.
Liqquid
43
Nov 22, 2024 07:30 AM
Evo_Xela
14
Nov 16, 2016 12:16 PM
NoReason
Jul 29, 2015 06:35 PM
re-rx7
Oct 21, 2012 02:24 PM
evoe85
21
Sep 13, 2012 08:32 PM
