Evo IX 2.4 cam noise?
Old Jan 17, 2015 | 05:46 AM
Twhunt's Avatar
I just finished installing my engine and it's making squeaking noise that sounds like it's coming from the cam area. I removed the serp belt to try an narrow down where the noise is coming from and the squeak is still there. If anyone could give me an idea as to what it could be I'd appreciate it.
Here is a vid
EVO 9 what's this noise?: http://youtu.be/IbOdkOVOipg
Old Jan 17, 2015 | 09:08 AM
06EvoIXmr07's Avatar
Either your timing belt is to tight or you may have this issue,
https://www.evolutionm.net/forums/ev...elt-video.html
Sounds almost identical.
Old Jan 17, 2015 | 04:07 PM
Twhunt's Avatar
Thank You
I read the thread you suggested and it appears the timing belt is possibly too tight. Poured a little water on the belt and the noise instantly went away. I'll look into how to adjust the tension on the belt. From what I understand it's adjusted by the off center pully above the tensioner.
jonwtf416
Apr 15, 2015 09:35 PM
evotris
13
Jun 27, 2008 04:22 AM
threefiftyse7en
Aug 24, 2007 02:37 PM
BEANIE
16
Oct 24, 2006 06:08 PM
dsevo
22
Apr 24, 2006 01:04 PM
