Fuel Pump Wires Extremely Hot
Old Feb 26, 2015 | 09:10 AM
jameswwt's Avatar
Originally Posted by michaelrc51
What size fuse is in the stock location?
Hi Michael, sorry for noob question but which fuse are you referring and where is it usually located?
Im using 30amp Relay
Old Feb 26, 2015 | 09:57 AM
michaelrc51's Avatar
Originally Posted by jameswwt
Hi Michael, sorry for noob question but which fuse are you referring and where is it usually located? Im using 30amp Relay
The stock fuel pump fuse.
Please explain how you are using the 30amp relay?
All I see are OEM wires in you pics. Those wires will not support 30amps and this would be the reason why they are hot.
Old Feb 26, 2015 | 10:14 AM
jameswwt's Avatar
Hi Michael, i will take some pictures on the 30amp Relay tomoro but basically the mech have tap the fuel pump relay and hotwire it directly onto the fuel pump wires which shown on the attached pic where the black casing is (Pls refer to the Pic No.1).
There is 2 wires tapping out from the original fuel pump wires to the relay socket.
Old Feb 26, 2015 | 10:17 AM
Hi Michael, i will take some pictures on the 30amp Relay tomoro but basically the mech have tap the fuel pump relay and hotwire it directly onto the fuel pump wires.
Just look at the relay and tell me where each wore that comes off of the relay goes to
Old Feb 26, 2015 | 10:34 AM
jameswwt's Avatar
Noted.
Old Feb 26, 2015 | 12:44 PM
M4Lki3r's Avatar
Veteran: Marine Corps
Ok, the problem is that you are using an aftermarket pump on the stock wiring system. Those wires are gauged high enough for the current the pump is pulling.
Directly from Aeromotive's Installation Guide found here:
The factory fuel pump wiring may not be sufficient to handle the current draw of the Aeromotive 340
Stealth pump. To achieve the advertised flow at pressure, the use of an aftermarket wiring kit such as
Aeromotive P/N 16301, including 10-gauge wire and a direct alternator supply point, is required.
Old Feb 26, 2015 | 02:57 PM
Originally Posted by M4Lki3r
Ok, the problem is that you are using an aftermarket pump on the stock wiring system. Those wires are gauged high enough for the current the pump is pulling. Directly from Aeromotive's Installation Guide found here:
Yeah, but there is more to it than that.....
With more info people will be able to help him out....
Old Feb 26, 2015 | 05:38 PM
jameswwt's Avatar
Thank you so much Guys and can i know how to reroute the after market wiring kit?
Thanks
Old Feb 27, 2015 | 05:06 AM
Thank you so much Guys and can i know how to reroute the after market wiring kit? Thanks
Follow this
http://www.streettunedmotorsports.co...rewire_kit.htm
If you can't follow that then you should take it to someone who can do it.
Old Feb 27, 2015 | 09:18 AM
jameswwt's Avatar
Follow this
Thank you so much Michael
Old Feb 27, 2015 | 09:27 AM
jameswwt's Avatar
Hi, do anyone here got the link on the Aeromotive Aftermarket Rewire Kit for Aeromotive fuel pump 340L?
Thanks
Old Feb 27, 2015 | 01:48 PM
Hi, do anyone here got the link on the Aeromotive Aftermarket Rewire Kit for Aeromotive fuel pump 340L? Thanks
That pump would be wired the same.......a pump has pos and neg leeds......
No offense but I think you should find someone who understands it and can install it.
Old Feb 27, 2015 | 04:42 PM
jameswwt's Avatar
No offense at all Michael and Thank you.
Old Mar 3, 2015 | 06:56 AM
mrfred's Avatar
i'm sure that i preach this too much, but standard hard rewire kits have their own issues. since the pump runs full time at full voltage, this causes 1) fuel pressure overrun at idle and totally messes up idle tune, 2) causes fuel pump to heat up faster, 3) wears out the pump faster.
if i were you, i'd figure out what's causing your stock wiring to overheat, fix that, and then do a fuel pump wiring supplement as i describe in:
https://www.evolutionm.net/forums/ev...e-circuit.html
Old Mar 4, 2015 | 04:52 AM
jameswwt's Avatar
Thank you Mrfred
Carloverx
14
Dec 22, 2011 01:00 PM
06MREvo
50
Mar 5, 2011 07:04 PM
broeli
34
Oct 9, 2003 11:59 PM
