Fuel Pump Wires Extremely Hot
Old Feb 13, 2015 | 10:35 AM
jameswwt's Avatar
Hi Guys,
ive just rebuilt my Evo 5 and have shifted my N70 car battery to the rear.
The problem is, whenever i go for 2~3 pulls my fuel pump wires goes extremely hot and seems some wires started to show sign of melting.
Ive added 30amp relay and its still the same.
Some says, its due to insufficient Grounding and i wonder is there any way of improving the problem? I am concern when the wires got too hot, it will reduce voltage to the fuel pump.
Im running on Aeromotive 340L pump.
Is there a way, where we could connect/ bypass a + wire direct & - Ground
to the fuel pump wires?
Currently the Fuel pump wires is from front main Fuel Box back to rear fuel pump. Is it possible to connect wires from rear battery + & - terminal direct to fuel pump wires?
If yes, pls do kindly advise.
Thank you.
Old Feb 13, 2015 | 02:20 PM
Ev0ikon's Avatar
I suggest you buy a fuel pump rewiring kit with its own relay. Right now you are powering the pump from the battery in the trunk, all the way to the front of the car's distribution block and then back to the rear to the fuel tank. That's a lot more resistance. And that pump pulls a lot!
Stop driving or your car until it's resolved or it may catch on fire!
Old Feb 13, 2015 | 02:31 PM
LetsGetThisDone's Avatar
OEM wiring is notorious for not be enough for aftermarket pumps. Order a rewire kit, or hardwire the pump using the OEM wiring to switch a relay, and a 10 gauge wire directly from the battery (with a fuse) to power the pump through that new relay.
Old Feb 13, 2015 | 03:50 PM
michaelrc51's Avatar
It says he put in a 30amp relay kit.
Any more info on this and how it was installed?
Usually hot wires would indicate either a bad ground or you are pulling to much amperage through improperly sized cabling.
Old Feb 13, 2015 | 04:54 PM
jameswwt's Avatar
Thank you Guys and how should i improve the :
1) Grounding? Do i need to connect a Ground wire from the battery - Negative terminal directly to the from chassis?
2) Can kindly share a link where i can purchase a Rewire Kit?
Yes, one of my mech friend said the same as Michael and yes, some wires to my fuel pump is irregular size.
Will take some pics and post it here later
Old Feb 13, 2015 | 09:13 PM
Ausevo7's Avatar
http://www.streettunedmotorsports.co...rewire_kit.htm
Old Feb 13, 2015 | 10:07 PM
jameswwt's Avatar
Old Feb 15, 2015 | 08:28 AM
jameswwt's Avatar
Hi, do anyone could kind enough to advise or share the fuel pump rewire diagram as per STM rewire kit?
Thanks
Old Feb 19, 2015 | 10:43 PM
mrfred's Avatar
did the hot wiring begin after doing the battery location change? where along the harness are you noticing the hot wires?
Old Feb 20, 2015 | 09:38 AM
jameswwt's Avatar
Hi MrFred, no its aledi happen before the battery relocation. i will take some pictures tomoro.
There's 1 wire which seems to connect to 2 wire together (1+2) is extremely hot below the rear passenger seat and the rest is exactly near to the fuel pump socket.
Will take some photos and reconfirm again tmr.
Old Feb 20, 2015 | 09:47 AM
Originally Posted by jameswwt
Hi MrFred, no its aledi happen before the battery relocation. i will take some pictures tomoro. There's 1 wire which seems to connect to 2 wire together (1+2) is extremely hot below the rear passenger seat and the rest is exactly near to the fuel pump socket. Will take some photos and reconfirm again tmr.
Sounds like you have some botched up wiring.
Please describe how your setup is wired.
Old Feb 24, 2015 | 08:45 AM
mrfred's Avatar
photo?
Old Feb 26, 2015 | 02:27 AM
jameswwt's Avatar
photo?
Hi MrFred, sorry for the delay and here are the pictures for your kind comment.
On the picture no.2, its the wire which welded and lump onto 2 wires. This is the on wire is hot and other wires around this wire no sign of hot.
On pictures no 4 & 8 the whole lump wires is very how. Not sure whether its just 1 or whole lump wires is hot.
Picture no.5, show wires going into the fuel tank area where the pointed wire is very hot and the rest is ok.
Dont know what wire on picture 6? Its located at the rear passenger side.
How do the STM Rewire Kit work on my current wires setup?
Attached Thumbnails Fuel Pump Wires Extremely Hot-1.jpg   Fuel Pump Wires Extremely Hot-2.jpg   Fuel Pump Wires Extremely Hot-3.jpg   Fuel Pump Wires Extremely Hot-4.jpg   Fuel Pump Wires Extremely Hot-5.jpg
jameswwt's Avatar
Fuel pump wires
Attached Thumbnails Fuel Pump Wires Extremely Hot-6.jpg   Fuel Pump Wires Extremely Hot-7.jpg   Fuel Pump Wires Extremely Hot-8.jpg   Fuel Pump Wires Extremely Hot-9.jpg
Old Feb 26, 2015 | 04:19 AM
What size fuse is in the stock location?
