2.1L timing help...
Old Mar 26, 2015 | 09:37 AM
babaz7's Avatar
2.1L timing help...
ok so i did the timing belt install on my 2.1L engine, it has a 4g63 evo 9 belt, just wanted to know that the tension is correct when you can easily slide in and out the grenade pin from the tensioner after all the timing marks are lined up, is that correct?
Old Mar 26, 2015 | 09:58 AM
badev0's Avatar
That is correct. You want to make sure the pin can easily go in and out AFTER spinning the motor over by hand. I usually spin it to TDC 6 times to be safe.
Old Mar 26, 2015 | 04:14 PM
Fast_Freddie's Avatar
Veteran: Navy
I spin the motor to TDC 3 times and let it set 30 minutes, if I can slide the grenade pin back in I call it good
Old Mar 26, 2015 | 10:13 PM
babaz7's Avatar
yes first i let the tensioner sit for 15 mins before turning the motor over by hand 6 times, then it was a little snug, so i loosened the tensioner pulley bolt and turned the two holes in the pulley counter clock wise, again waited 15 mins before turning the motor over, after that i came in and out like butter.
i think i have the right tension set, fingers crossed.
evotris
29
Sep 8, 2013 07:26 AM
Paintballer81
Apr 1, 2010 12:40 PM
Bosshog
Jun 13, 2007 08:54 AM
superman105
Mar 11, 2005 05:36 PM
