Play in piston/rod...
Old May 17, 2015 | 08:18 PM
CeliOnce's Avatar
I'd just say put in a new set of bearings. Worse case scenario you end up doing a rebuild either way. Although you're crankshaft might be more salvagable in it's current state if you rebuild right now.
Old May 17, 2015 | 11:02 PM
WikdEvo's Avatar
The bearing material has chipped off and has contaminated the motor. I'd bet that if you just put a new bearing in that it'd spin in short time.
Old May 18, 2015 | 06:35 AM
Aby@MIL.SPEC's Avatar
i must have missed your video before.....
bearings or not, you should only have between 0.003-0.007 thrust for most rods makers... pauter usually runs looser than posted above, but those dont look like pauter rods.
i would pull all remaining pistons & rods & go thru eveything, it will only take a few more minutes, especially since the head is off.
i would be concerned about the journal of the crank & the thrust areas where the wiped out bearing was running.
Old May 18, 2015 | 11:50 AM
LetsGetThisDone's Avatar
Judging by that bearing, the crank is probably pretty beat up. You'll like spin, or pretty shortly destroy a new bearing if you don't address the condition of the crank.
Old May 18, 2015 | 12:25 PM
tscompusa's Avatar
Do not just put new bearing in there. It definitely needs rebuilt. Send me a email or PM if you want help or you want to rebuild it yourself ill sell you the parts and give you some tips along the way, but when assembling its best to measure all clearances with gauges and so forth.
Also rod side clearance for most aftermarket rods based on the evo rod journal dia is actually .010-.012. and most do not clearance them, so manley turbo tuff end up around .008" but I dont recommend them that tight. I open them up because i try to do everything by the book.
If they are to tight, oil wont be able to escape from the cap as efficiently, and if you cant move oil quick enough the cap gets hot.
I would also replace the oil cooler in that engine for peace of mind. Once contaminates get trapped in the cooler they are impossible to flush out.
crcain
Apr 29, 2009 12:38 PM
bradc
Feb 28, 2009 02:19 PM
kkarim
Feb 11, 2008 05:40 PM
gofaster87
Jan 8, 2007 03:30 PM
