Reseating throw out bearing?
I'm reinstalling my trans on my engine and I'm having trouble reseating the throw out bearing. I'm pulling the fork just about as hard as I can and I'm worried about breaking something. Do I just have to put a lot of force on it or is there some trick? Thanks
It is Binding if it takes so much force to "snap" back in.
I found the trans bell housing coming back easier if the back is jacked a bit higher than the front of the car.
Take your time man. It is very easy to bind it up. Grease the input shaft going back also.
I placed a deepwell socket over the arm so I had something to hold on to and then gave a mighty tug. This was tob going into a Monoloc. It snapped right in. If that doesn't work I think something is wrong.
I've got the monoloc as well. Does the monoloc go in front of or behind those wavy snap rings? I thought I took it apart with the snap rings between the pressure plate and the monoloc, so maybe that is what I have wrong.
Sorry I didn't use the Monoloc so I can't be certain. I know that with the stock keeper it would not take that much force to "click" in.
Sounds like you have the wave springs in correctly.
Cj98
Jun 28, 2013 12:00 AM
Cloudx71
Sep 10, 2011 01:14 PM
spyderturbo
Jul 25, 2003 11:41 AM
