FP Oil Line and Engine failure
Old Jul 10, 2015 | 10:46 PM
Insanity Evo's Avatar
Hello EvoM. I'll try to keep this short. Last year my motor jumped timing and everything was toast. I finally have everything on its way to finish getting rebuilt. However, I am wondering if I need to replace the FP oil filter housing kit that came with my JB FP Black? I will be replacing other things such as the OEM oil pickup tube and the oil cooler, but this I am unsure of?
Would anyone be able to be of some help? I think I have all the bases covered otherwise, but is there anything else I should look to replace? Thanks in advance!
Old Jul 11, 2015 | 05:09 AM
evo8426's Avatar
It would be highly recommended to clean out the filter at a minimum. For $250 and peace of mine it wouldn't hurt to just replace it.
Old Jul 11, 2015 | 05:41 AM
Bhsj13's Avatar
just replace it.
Old Jul 11, 2015 | 10:07 PM
Will do. Thanks!
Old Jul 15, 2015 | 06:55 AM
batty200's Avatar
Originally Posted by Insanity Evo
Will do. Thanks!
FP sells replacement filter elements for a very reasonable price. However a timing belt that jumped there is no need to replace anything oil related unless it was caused by a bad bearing or oil pump locking the motor.
Old Jul 15, 2015 | 12:43 PM
The motor was destroyed and valves broke into pistons. There was a lot of debris.
Old Jul 18, 2015 | 04:59 PM
WHTEVO's Avatar
I would also replace the oil pump/ front cover, and flush out both of the oil cooler lines while you have the old one out to be on the safe side.
Old Jul 18, 2015 | 10:10 PM
doubleSUSTANON's Avatar
A replacement filter cost $2.50 from FP.
Jonh317
May 10, 2018 05:51 PM
Anarchy99
47
Dec 13, 2012 02:40 PM
I4UnderPressure
49
Aug 11, 2012 04:41 AM
cij911
11
Nov 14, 2011 08:18 AM
