p0090
Old Jul 25, 2015 | 01:28 PM
Gallagher444's Avatar
p0090
I missed a gear on the highway the other day and bounced of the rev limiter, ever since then im getting a p0090 code. Car seems to being running fine, a/f is right where it should be same with boost. Any suggestions??
mods.
fp green turbo
1100 fic injectors
maperformance downpipe
evo 9 bov
tial wastegate
walboro 255
Old Jul 26, 2015 | 09:45 AM
anyone??
Old Jul 26, 2015 | 12:29 PM
barneyb's Avatar
The code is for the fuel pressure solenoid. When the solenoid shuts off it puts out a 2 volt signal that the ECU looks for. So, it is just a (is the solenoid there?) sort of test. And it should not affect driveability, it is only for hot start.
So. wiring or the solenoid itself should be suspect. The thing is, this code pops up from time to time for seemly no reason. I have never seen a fix for when this occurs.
Old Jul 26, 2015 | 01:40 PM
Good info man. It's just annoying because I need an inspection sticker and I keep clearing it but it just comes back on. And the solenoid is still in the car.
Old Jul 27, 2015 | 12:58 AM
barneyb's Avatar
If repair is unsuccessful maybe your tuner can make the ECU forget the car has a fuel pressure solenoid.
Old Jul 28, 2015 | 09:08 AM
heel2toe's Avatar
My buddy is having issues with the P0090 as well but this was caused from the wrong wire being plugged into the fuel pressure solenoid. We shut off the code in the ECU and as of right now the readiness tests are coming back in ready status which was a concern since I think disabling the P0090 also kills EGR and EVAP. He's going to get a sticker either today or tomorrow and keeping my fingers crossed he doesnt gat flagged and sent to a MAC center.
But I will update this thread with the results and if it worked then I can help you disable the code
Old Jul 28, 2015 | 04:00 PM
Nothing worse than driving around wit a check engine light on . Ya lmk man I'm going to new Jersey for a few days so I can't fix it right away anyway. But let me know what you guys come up with!
Cheers
Old Aug 10, 2015 | 09:53 AM
heel2toe's Avatar
Just wanted to come back in here with an update. Not sure if you got this sorted out but we were able to delete p0090 without killing both EVAP and EGR so my buddy was able to get a sticker. If you are still struggling PM me and I'll see if I can help you out.
fireroasted
Dec 17, 2013 04:41 PM
Mellon Racing
41
May 6, 2013 03:20 AM
boosted91t
Feb 9, 2012 01:29 PM
Brian0206
Lancer Troubleshooting
Jul 18, 2009 06:06 PM
05-EVO-GSR
Mar 17, 2008 11:01 PM
