Low boost
Old Jul 31, 2015 | 06:25 PM
Zach S's Avatar
Low boost
Im looking at a 2003 evo with a bigger turbo than stock. This will be my first evo so I do not have much experience with the car. THe owner told me he thinks it just needs a tune since it has not been tuned after the upgrades were put on it. I was wondering if anybody had any ideas. I know it has a large turbo, ic, pipes, cams, and I believe headers. All I know is he says it is low boost. Would a tune take care of this issue since it may just not be getting enough fuel for the larger amount of air being forced in?
Old Jul 31, 2015 | 08:08 PM
Bhsj13's Avatar
can you get a nice photo of the engine bay, turbo inlet with pipe off?
Old Aug 1, 2015 | 03:39 AM
evo8426's Avatar
If the car was modded but neglected to get tuned, imagine what other shortcuts might have been made...
Old Aug 1, 2015 | 08:51 AM
Ted B's Avatar
Originally Posted by Zach S
...it has not been tuned after the upgrades were put on it.
That doesn't work.
Here's what you will need to do before you attempt to retune anything. Otherwise, like the previous owner, you'll be wasting your time and money.
https://www.evolutionm.net/forums/ev...g-how-why.html
Old Aug 1, 2015 | 10:43 AM
sparky's Avatar
Do you have any idea what turbo is on there? Does it have larger injectors and higher volume fuel pump?
Old Aug 3, 2015 | 06:08 PM
Zach S's Avatar
I do not know what turbo is on it, I know its a larger turbo, I believe I was told hks, it was the one used in the 2014 hyundai genesis commercial, its a decent price which is why im considering it. I am also unable to get pictures of the engine bay. Ill do the boost leakdown test and listen for vacuum leaks. The owner said he got it untuned from the studio, it was bought by universal originally, possibly for the fast and furious movies, so thats kinda a cool bonus. I was thinking a tune could fix based off of a fueling issue since more air would be compressed into the cylinder, leaning it out and causing it not to pull. Is there a way to check boost levels without the gauges in it? thanks for all the replies. Ill let you know if i get the car too.
Old Aug 3, 2015 | 10:26 PM
sparky's Avatar
1st of all install a boost gauge.
Old Aug 4, 2015 | 04:47 PM
Zach S's Avatar
I was planning on t. I just didn't know if there were other ways to check boost of you don't have a gauge
Old Aug 5, 2015 | 10:18 PM
sparky's Avatar
You mention that your Evo might have an HKS turbo upgrade. This would probably be the 7460R. If so, it would be relatively simple to corroborate. The 7460 is easy to identify as it has a blue metal plaque on the compressor housing as well as the raised HKS letters cast into the compressor housing.
The earlier versions of this turbo were notorious for losing tension on the wastegate which could be causing your low boost scenario. The problem was due to the cobby looking segmented actuator rod. The problem was supposedly rectified on the later "Kai" versions of this turbo.
Old Aug 9, 2015 | 05:01 PM
Zach S's Avatar
well I went and looked at the car, its got all sorts of issues. we romped it and pushed 5 lbs of boost, and checked everything else, at idle timing was advanced 30 degrees, so needless to say, it was a dud. thanks for all of your replies though.
LancerShop.com
Lancer Vendor Classifieds
Oct 27, 2016 06:25 PM
SoCalRedLine
Jun 19, 2013 09:40 AM
speedfreak24
Feb 15, 2010 08:35 PM
Show Off
Feb 25, 2008 10:52 AM
JSC Speed
Oct 26, 2005 07:40 AM
