Where might this oil come from?
Old Aug 28, 2015 | 08:00 PM
dsmchiz's Avatar
Thoughts on where on the turbo this oil would come from? Noticed it today. Nothing under the car I was just looking around and saw it. When I saw it the car was cold and the oil was very dry. I had to scrape it with my finger nail to remove a piece of it.
After driving I am seeing a little fresh oil on the bolt or whatever that is. Not leaking enough for me to have even noticed I just happened to cross it. It's on the bottom of the turbo.
Thanks all!
Attached Thumbnails Where might this oil come from?-20150828_201522.jpg   Where might this oil come from?-20150828_124721.jpg
Old Aug 29, 2015 | 08:45 AM
MR ArcticC's Avatar
I would check the oil feed line fitting first. It's on the other side of the turbo. Looks like the return pipe fitting on the picture is dry.
Old Aug 29, 2015 | 09:11 AM
kaj's Avatar
kaj
agreed. follow the line upward to find the source.
Old Aug 29, 2015 | 10:56 AM
LetsGetThisDone's Avatar
It's either a small feed line leak, or you're pushing a little into the turbine housing. If it's the latter, consider crank case ventilation upgrades..
Itchy
Feb 25, 2007 05:41 PM
js06evoix
Northwest Region
May 25, 2006 05:54 PM
perfdrug
Jul 23, 2002 11:33 PM
