P0113 Code with Speed Density
Old Sep 5, 2015 | 10:37 AM
yositoco's Avatar
I threw a P0113 code a few days ago and would like to get to the bottom of it. It's a Intake Air Temperature Circuit High Input code. I have been running SD for a while now without any issues.
When I checked the IAT values on evoscan it gave me a -74.2 degrees.
Any ideas on how and what to check?
Old Sep 5, 2015 | 11:36 AM
LetsGetThisDone's Avatar
Are you running an IAT sensor? If so, it's likely bad...
Old Sep 5, 2015 | 11:47 AM
yositoco's Avatar
I am. But even if i disconnect the iat and clear the code it comes right backeven before i turn the engine on.
Old Sep 5, 2015 | 01:06 PM
evo8426's Avatar
Switch to fuel temp based and see if it goes away
Old Sep 5, 2015 | 04:07 PM
yositoco's Avatar
will try. thanks
Old Sep 6, 2015 | 01:41 PM
Well, of course it comes back if the sensor is unplugged...
Old Sep 7, 2015 | 09:47 AM
black_out's Avatar
Ohm the sensor and make sure it still has resistance. I've had multiple IAT's I've blown the element out of. You can pull the sensor and look in it and see if the elements missing, but ohming it is faster.
kaj
16
Jul 2, 2014 12:39 PM
mr2driver
Aug 14, 2011 08:25 AM
Macaroni
21
Jun 16, 2009 12:50 PM
CrackerJackToy
Nov 21, 2007 04:15 PM
mjones53
Feb 25, 2004 03:08 PM
