Evo 8/9 reliability whp/wtq?
Old Sep 8, 2015 | 05:40 PM
Tommyy's Avatar
I've done some searching and I can't really find a definitive answer on the whp/wtq the car can reliably hold. I know the 4G63 can take roughly 400 whp. As for the trans t case and diff i know they're a little more susceptible to failure. I know it varies relative to use, supporting mods, and preventative maintenance but are there any safe numbers? Or what numbers and mods are you running and with what problems? Thanks all.
Old Sep 9, 2015 | 01:20 PM
LetsGetThisDone's Avatar
This stuff is well documented if you read around. And the engine can handle ~400wtq. How much power it produces with that much torque depends on what turbo you're using.
Old Sep 13, 2015 | 08:22 PM
ridenrunwv's Avatar
Turbo should not make any difference. That would make a difference in how much boost it takes to make a give power level but horsepower is a calculation of torque and RPM.
HP = (TQ x RPM) / 5252
Old Sep 13, 2015 | 08:48 PM
Yes it does. A bigger turbo can hold boost, and make more torque at 8000rpm, thus, more horsepower...
Old Sep 14, 2015 | 06:32 AM
ridenrunwv's Avatar
Now I see what you're saying. My Green at 100% WGDC makes around 30 psi at 7500 RPM but a Red or Black could make more boost and more power on the top end?
Old Sep 14, 2015 | 06:48 AM
Tommyy's Avatar
Smaller turbos offer more low rpm boost and fall off at the top where as the bigger ones take a little longer to spool up but continue to increase boost
DjRags604
Sep 24, 2012 09:17 PM
Boost MR
Evo X Dyno Results
24
Jan 1, 2010 02:07 PM
meisnerboy
European Forum
10
Mar 4, 2009 09:19 AM
HPF Tom
Dec 21, 2006 12:11 PM
meisnerboy
Australian Forum
17
Jan 17, 2004 03:34 PM
