Balance shaft too tight?
Old Sep 23, 2015 | 03:11 PM
Brownmiata's Avatar
Hey everyone. I have been rebuilding my motor for a couple months and it just came to installing the front of the motor (oil pump, timing belt) and I noticed one of my balance shafts spins back and forth easily. The other one is tight. And will spin when the timing belt it attached and I am spinning the whole motor. I measured it and it takes about 5-10 ft-lbs to move it.
If this is normal that would be great. What I've gathered from my research is that
A. The machine shop mushroomed one of he bearings and its sticking.
B. Oil pump was tightened with the wrong bolts/wrong size bolts and it's causing a bind.
Should I just remove them?
thank you.
BM
Old Sep 23, 2015 | 05:43 PM
LetsGetThisDone's Avatar
That's definitely not right. They should both spin freely with assembly lube in there. Definitely pull it apart and see what's going on.
Old Sep 23, 2015 | 05:56 PM
Brownmiata's Avatar
Thank you. That's just what I needed to hear. I'm glad I didn't put the rest back together.
Thanks again!
Old Sep 25, 2015 | 11:12 AM
cerevo's Avatar
may have to take it to the machine shop and let them run a polish cloth on it or something if its just barely too tight
Old Sep 25, 2015 | 01:05 PM
honda-guy's Avatar
did you install the balance shaft bearing yourself, with the correct bearing driver. might have nicked the bearing lip a little, could probably ream it out the lip.
Old Sep 29, 2015 | 05:50 AM
kpr's Avatar
kpr
thank you.
BM
you cant be spinning both shafts .
The one on the left is the balance shaft, one on the right is the oil pump( oil pump spins the balance shaft)-it should be harder to turn. Assuming you have the oil pump on
Old Sep 29, 2015 | 11:42 AM
The difference is marginal, and certainly not 5-10 ftlbs. Maybe 10-20in-oz's..
Old Oct 1, 2015 | 12:20 PM
Brownmiata's Avatar
Its actually 12ftlbs. I made 2 videos. One of the digital torque gauge to get a running torque. And the other to see if anyone can wrap their head around what the hell is going on. You can see in the video me spinning the balance shaft then when it hits the back wall it just stops then gets super hard to turn.
Thank you guys. There is a eliminator kit on its way. in-case it doesn't go as planned.
Old Oct 1, 2015 | 12:21 PM
Brownmiata's Avatar
Embedding the videos wont work..
Old Oct 5, 2015 | 06:06 PM
Brownmiata's Avatar
Balance shaft eliminator came in today. Guess ill just install that...
Old Oct 5, 2015 | 06:10 PM
Sorry man, I didn't see the video's until now, there is definitely something wrong with the bearings on that shaft.
At lest with the delete kit it doesn't matter if you booger them up a little bit because they're only going in to block off the oil ports.
Old Oct 5, 2015 | 07:04 PM
Brownmiata's Avatar
Thank you so much! Yeah i figured it would be much easier to not screw up the block or have that in the back of my mind the whole time till I start the car then hear some funky noise. I just want it to start.
I bought all the timing belt tools and they arrived today looks like ill have my work cut out for me here the next couple days!
Old Oct 5, 2015 | 07:14 PM
The timing belt is really easy as long as you have the tool that slides in between the cam gears to hold the cams in place.
Old Oct 5, 2015 | 07:20 PM
Brownmiata's Avatar
I got the Jay racing kit that has like 3 tools. only thing I'm wondering if I can re use the stock head bolts again. I didn't want to drop another 200$ on studs.
But some people I have read say you cant reuse them. Any insight?
Old Oct 5, 2015 | 07:21 PM
Brownmiata's Avatar
they are only 118$ so its not a big hit if I HAVE to buy them.
