intake pipe options for FP 84mm compressor covers
Old Oct 4, 2015 | 12:27 PM
KFC-AWD's Avatar
Does anyone that uses FP 84mm comp cover Evo 8-9 turbos like the 71HTA, Red, etc use any other intake pipes besides the FP silicone pipe? I have the FP one, but its a really tight fit.
Thanks
Old Oct 4, 2015 | 01:28 PM
LetsGetThisDone's Avatar
It's supposed to be a tight fit. I have a 3.25-3" reducer for my 3" metal intake pipe. It's a tight fit on the compressor housing.
Old Oct 4, 2015 | 01:37 PM
KFC-AWD's Avatar
does it hit that wire loom behind the compressor cover? I had to push that thing hard to fit their silicone pipe past the wire loom and it still doesnt slide all the way on the comp cover, maybe their pipe is just thicker?
Old Oct 4, 2015 | 02:37 PM
ridenrunwv's Avatar
I do the same thing without a problem.
Old Oct 4, 2015 | 04:46 PM
No, I removed the "mount" for the wire loom that's right under the turbo and routed it out of the way.
Old Oct 4, 2015 | 05:26 PM
ridenrunwv's Avatar
I used a 3.5 inch reducer now that I think about it.
Edit... Never mind. It must be 3.25 because I squeezed it on and 84 mm is around 3.3 inches.
Old Oct 4, 2015 | 05:29 PM
KFC-AWD's Avatar
Ahh ok, is it just one bolt holding that mount? Which metal pipe do you use?
Old Oct 4, 2015 | 06:51 PM
Yea, it's on on bolt. Its a 10mm head that is right under the turbo, the head points to the passenger side of the car.
The pipe I use is an ETS intake, but I cut the recirc port off and sealed it up since I'm running a vta bov, and I install it "backwards"..
usernameinuse
Jul 21, 2013 09:20 AM
BoostINurI
May 24, 2011 05:59 PM
kevinlubitski
May 12, 2011 06:44 AM
Evoryder
36
Jul 31, 2010 01:56 PM
