Can you reinforce a 6speed MR Tranny?
Old Oct 16, 2015 | 07:50 PM
  #61
Lombardi23's Avatar
Originally Posted by kyoo
:: why not start with a 5spd then? Or didn't you use to run a X SE/MR with paddle shifters?
Does the 5 speed have extremely high rev? Like, being in 5th being around 80mph, seems the rev is around 4k already, is that normal for everyone else?
Old Oct 17, 2015 | 02:36 AM
  #62
Benja's Avatar
Are you guys sure its the same set?
Im 99% sure PPG here made the first run of 6sp kits for Shep.
Also PAR (Precision Auto Robotics) in Sydney has made billet upgraded gears for a 6sp guy locally as well.
Old Oct 17, 2015 | 04:53 AM
  #63
ridenrunwv's Avatar
I was curious about it being the same also because I thought Shep quit building them because of problems getting the gearsets.
Old Oct 17, 2015 | 07:00 AM
  #64
Thrilla's Avatar
Veteran: Army
Originally Posted by ridenrunwv
I'm still debating on whether I should even mess with upgrading my 6 speed or swapping it before I build mine. The car is already down so it seems like a good time to do it but the expense would add a good bit to how long before I get the car running again. Any of you run decent power on a stock 6 speed for a period of time?
There's a thread here regarding 6-speed owners and power levels. I'm still on the stock 6-speed at 390 tq. I've been on this power level for a few years. The general consensus is that it'll hold, but can lead to failure in the long run.
If you have the time and resources, it's a good idea to reinforce depending on your use.
Old Oct 17, 2015 | 08:23 AM
  #65
ridenrunwv's Avatar
I'll be going built motor and am still undecided on exactly what turbo and engine I'll go with but over 500 lbs ft of torque is in the plans.
Old Oct 17, 2015 | 12:36 PM
  #66
kaj's Avatar
kaj
we all plan 1,000,000whp/tq.. but as long as you are being realistic about your build, then you can make an educated decision on what you need.
Old Oct 17, 2015 | 12:40 PM
  #67
DSMraver's Avatar
We have a Shep-built PPG 6 speed here if someone is interested in purchasing the gearbox... PM for details. We put a 4.11 final drive ultimate ratio 5sp in for drag racing (140+traps goal) or we'd still be running the 6sp.
Old Oct 17, 2015 | 05:07 PM
  #68
kaj's Avatar
kaj
dang it. i wish.
RevLimiter
Aug 20, 2012 07:01 PM
rick@sp
11
Apr 17, 2009 06:42 PM
zedevo
Jan 9, 2009 09:55 AM
cetinsaya
27
Nov 8, 2007 08:09 AM
vmrevo9
19
Sep 13, 2007 08:13 PM
