Cant make more then 500hp. Stumped-Help!
Old Nov 6, 2015 | 07:09 AM
STLEVOIX's Avatar
Unhappy Cant make more then 500hp. Stumped-Help!
My friends evo 8 has a built 2.0 stock crank, Manley I-beam rods, Weisco pistons, CBRE ported head, GSC S2 cams/Kiggly be-hive springs, ported intake/TB/exhaust manifold. Turbo is an FP Black with a 25psi waste gate and o2 dump. It has a QTP 3” downpipe with exhaust cutout. FIC 2150cc injectors, double pumper w 2 255’s(both pumps kick on-verified), ETS intercooler pipes, 3.8” Slow Boy Racing FMIC, Grimmspeed 3 port EBCS. Fuel is e85.
He cannot make more than 500hp. At 38psi he is only making 502hp according to VD. He can not up the boost any more. Upping the WGDC will not affect it past 38lbs. He is running 16 degrees of timing up top and an AFR of 11.8-12.0 The car has been boost leak tested and holds good pressure up to 35lbs. The exhaust is about as free flowing as it gets. It dumps right after the downpipe with the cutout, plus a waste gate dump. The results are the same when we removed the air intake and just ran open turbo(this is on speed density). The plugs are new NGK Iridium gapped at .018. No misfires or hiccups at all. The vehicle has 170 compression across the board and less than 5% on a leakdown test. Does anyone have any idea what could be going on or what to look for next? All out of ideas here
Old Nov 6, 2015 | 07:27 AM
nemsin's Avatar
Maybe its an issue with VD? Is there a local awd dyno you could run the car on?
Old Nov 6, 2015 | 07:53 AM
STLEVOIX's Avatar
It ran against mine which is makin more power and i pulled on him. The car feels like a 500hp car. This setup should be making more power or am I missing something?
Old Nov 6, 2015 | 08:07 AM
kyoo's Avatar
is it definitely doing that much PSI? what do the logs look like? who tuned it?
glad to see you got another evo - would be cool to have an STL evo meetup some time. would like to see a few more out on the track and autox
Old Nov 6, 2015 | 08:14 AM
LetsGetThisDone's Avatar
Have you checked cam timing?
Old Nov 6, 2015 | 08:16 AM
STLEVOIX's Avatar
His boost gauge has a recall function which is about 38 and his OMNI 4 bar logs it and it hit 38.3.
Yea we should def do a meet up. May post on the FB STLEVO page and see who would be interested.
Old Nov 6, 2015 | 08:19 AM
rrstlevo's Avatar
--03 RR Evo VIII
--99.5 TDI
--02 300M Special (sold)
--95 Eclipse GSX (sold)
Old Nov 6, 2015 | 08:20 AM
STLEVOIX's Avatar
Cam timing is dead on. Its been triple checked multiple times.
Old Nov 6, 2015 | 08:22 AM
Originally Posted by rrstlevo
This is my car. It is making that PSI according to the gauge and the OMNI. TSCOMP is tuning it and he thinks I have an exhaust restriction or intake restriction. Running without an air filter no change and taking the exhaust off no change. Possible it may be the intercooler it is a no name brand 3.8" core. All piping and intake manifold has been removed and checked. Timing was checked a couple months ago (I've been having this issue for a year now.) - the gears are adjustable but not adjusted.
OP says its Garrett core FMIC, you say it's a no name. Which one is it?
Old Nov 6, 2015 | 08:29 AM
rrstlevo's Avatar
--03 RR Evo VIII
--99.5 TDI
Old Nov 6, 2015 | 08:45 AM
kyoo's Avatar
do it! link to the page? I'm not on that group I guess
Old Nov 6, 2015 | 08:47 AM
STLEVOIX's Avatar
https://www.facebook.com/groups/547678708602094/
Old Nov 6, 2015 | 09:12 AM
ETS Michael's Avatar
Might be time for an ETS 4" Intercooler.
Assuming the turbo is in good working order and nothing has gone through the wheels I would look at the intercooler.
- Robert
Old Nov 6, 2015 | 11:33 AM
Evo8cy's Avatar
If the intercooler is of a descent core, bigger than or of 600x300x76 with at least 2,5inch inlet/outlet and there are no inlet temperature issues, then the intercooler is not your problem. Yes a slightly bigger one will yield some more power but this is not what is causing the car to be of low power. I suspect there is a problem of valve float at such a degree that affects the V.E of the engine. I would also focus on the work done on the head.
Marios
Old Nov 6, 2015 | 11:38 AM
TrendSetter's Avatar
put a pressure gauge or sensor at the inlet to the intercooler and measure the difference compared to the omni 4 bar.
