Cant make more then 500hp. Stumped-Help!
If the intercooler is of a descent core, bigger than or of 600x300x76 with at least 2,5inch inlet/outlet and there are no inlet temperature issues, then the intercooler is not your problem. Yes a slightly bigger one will yield some more power but this is not what is causing the car to be of low power. I suspect there is a problem of valve float at such a degree that affects the V.E of the engine. I would also focus on the work done on the head.
Marios
Marios
Yes maybe they don't or maybe they do, the same goes for the head. If I take it as granted the fact that the kiggly springs are up to the task and the fact that everything else is as it should be, based on what I have read on this thread, then the only thing that I would put my focus on is the work done on the head.
Marios
No I can't say I am. Based on the nature of this thread and the way posts have been composed, a way that shouts that the built has been done with the best parts available I take into consideration the fact that the above said companies are also among those who are acknowledged as among the best. Since though I have not heard nor had any sort of personal experience of their products I have my doubts about what they can or can't do.
Marios
ant_turbo
16
Jul 14, 2010 12:21 AM
DB8GSR
Aug 30, 2002 03:01 AM
