fuel pump dying?
Old Dec 18, 2015 | 04:27 PM
kaj's Avatar
kaj
Originally Posted by barneyb
Ground!
I thought so...but I just installed the engine and know I attached all of them. I'll look over then again.
Old Dec 18, 2015 | 05:24 PM
kaj's Avatar
kaj
Update: it was something simple as I suspected. When I put the motor back in I never finished tightening the power wire from the alternator. The nut that holds it on was just about to fall off LOL
Old Dec 18, 2015 | 08:40 PM
barneyb's Avatar
Lol - you can't do that much work without missing something.
Old Dec 18, 2015 | 10:58 PM
LetsGetThisDone's Avatar
Nothing like shade tree mechanicing lol
Old Dec 19, 2015 | 07:44 AM
kaj's Avatar
kaj
true, true. i'm sure it was a "i'm gonna leave this for the night and come back tomorrow" types of things, then got busy on the top side of the engine, etc.
i'm just glad i didn't have to change the alternator.
Old Jan 3, 2017 | 09:11 PM
kaj's Avatar
kaj
update:
car started doing this again. I installed a new battery, just in case.
First symptom: I was driving home from work and the battery/oil lights started to flicker and the car was running rough. I do not remember the AFRs at that time. On the offramp, the car died on me. I restarted it and it drove fine the rest of the way home and to my friend's shop the next day. Battery and alternator check out find according to a volt and amperage meters. I was unable to check under the same load as on the freeway (RPM, lights, defroster, etc).
Today, I hook up EvoScan and I see this:
I test drove the car up and down the fwy with lights/defroster/radio on and noticed no problems. No flickering batt light, no power loss, and AFRs were all fine. I can not, for the life of me, get the ISCV to drop below 8. Yesterday it was at 0. This car is seriously pissing me off.
Old Jan 4, 2017 | 06:03 AM
Those low fuel trims. +3.8% on the long, and +12% on the short term. Boost leak test, then check injectors, then maybe toss a new walbro 255 in it because they're cheap, then possibly revisit the tune/tuner...
Old Jan 4, 2017 | 07:48 AM
kaj's Avatar
kaj
That's my checklist, so far. This was all of a sudden, so doubting it's the tune.
The battery light coming on during my trip home is what throws me off the most. I'm REALLY hoping it's not the alternator.
Old Jan 4, 2017 | 08:02 AM
4b11slayer's Avatar
Maybe your voltage is not wat it was when you got tuned, that might explain the fuel trims. How many miles on alternator
Old Jan 4, 2017 | 10:26 AM
kaj's Avatar
kaj
130k but it did spend a decent amount of time charging a bad battery.
Old Jan 4, 2017 | 08:56 PM
4b11slayer's Avatar
Have you had a alt test besides a meter to read voltage?
Old Jan 4, 2017 | 09:33 PM
kaj's Avatar
kaj
Just with an amp meter. Not on a bench, or anything.
CrazyLilPunk
Apr 24, 2016 04:17 PM
MisUnderStood
Dec 16, 2015 08:53 AM
Carloverx
14
Dec 22, 2011 01:00 PM
EVOtagger
Sep 26, 2006 01:47 PM
