GSC S2 cam with oem retainers?
That may hold true in a forged vs OEM piston or Bronze valve guide vs OEM steel/iron guide debate. But titanium is 100% without a doubt stronger and has a much longer fatigue life than aluminum.
Ive been beating on the GSC springs and OEM retainers with S1 cams for a few years. Stock engine banging on 7800rpms a ton, 2.3l banging on 8k wayy to much.. until it broke the 100mm crank. Now 2.2l but I rarely hit the rev limiter set to 8k. Will be bumping that to maybe 8500 this year, we'll see how adventurous I feel. But the caps have never been a worry of mine.
I only "upgrade" parts of I need to.
And I've learned that whenever one person tells me one thing and someone else tells me the opposite ,it usually means either way works.
Necrobump. What cams were you running when you cracked OE retainers? You're the only instance I've been able to find of this. @SW20Mike
It says springs or springs and retainers, which confirms what we've all been saying. Good info!
I forgot to mention I was also running MAP beehive springs, so possibly be ok with OEM springs with OEM retainers. However, I'd recommend just swapping it all out plus GSC valve stem seals at the same time.
ilirDukaEvox
23
Jul 27, 2016 06:52 PM
FS[Northeast]: Evo 9 GSC S2 cams and GSC stage 2 valve springs Ti retainers
honda-guy
Dec 30, 2015 04:53 AM
FS[Pacific NW]: GSC S2 cams with GSC beehive springs and retainers. BNIB
Xiled1
Dec 29, 2014 11:04 AM
AznSupraTT
Feb 17, 2014 03:47 PM
Sideck
10
Jul 13, 2010 08:50 PM
