Suggestions on a great quick response turbo
I'm hoping to 400-450/400 on pump gas. My cams are 272. Considering you made 345/300 on 91. It seems like my goals aren't hard to reach with turbo. My only concern is will I be pushing this turbo to hard? I'm also running the stock bov/dv on my 9 which should hold up for me unless I'm told to upgrade them.
I did 402whp on 93oct with the 71HTA. 23psi, Mustang dyno. It's a great little turbo and your goals are definitely attainable. I have a stock Block IX with Tomei 270s. I agree with Kobz in suggesting you replace your BOV and ensure you have no boost leaks. This turbo @ 23-24psi @ redline is already at the top of its range.
The 71HTA feels exactly like the stock turbo with a lot more power
I believe the green does have a larger turbine, which is why they have to machine the housing. I think they have always done that.
Maybe it's similar to the old White?
I don't know a ton about the OG Green, but since it was such an early FP turbo and pre-HTA aero, I would guess that you can get at least the same power from the 71HTA with better spool.
I did a 20g.. Basically took my evo ix turbo and had it rebuilt with a billet wheel and internals. Should be breaking 400+ HP after I swap cams. I am just at or slightly over 400 now on pump.. Has fairly quick spool and pulls great.. Just a different option..
I like the Dominator 1.0XT but that is only based on secondhand research I have done. Just picked one up but have not installed/tuned it. From what I gather it is nearly identical to the BBK Full and can get you to the 400 mark.
Informative review:
https://www.evolutionm.net/forums/ve...iew-boltz.html
Informative review:
Informative review:
Informative review:
This.
FP 18PSI WG actuator bolts on, (or OEM). The HKS design it came with failed at about 10k. Other than that, I have a first generation and have not had any WG flapper, or other issues yet. Love this turbo. I will probably buy another one as a spare -its that good-for if/when my current one needs a rebuild.
